y wont my VTEC engage? D15B
Old Apr 20, 2005 | 01:17 PM
I_love_my_HONDA's Avatar
Default y wont my VTEC engage? D15B
i recently baught my 91 hatch with a D15B vtec but my VTEC is not egaging what is the problem ????
Old Apr 20, 2005 | 01:21 PM
drdisco69's Avatar
Default Re: y wont my VTEC engage? D15B (I_love_my_HONDA)
Sounds like your VTEC isn't working... Is there anything else you can tell us? Check the wiring, check the oil, search for people who had the same problem (make sure you search the archives) and tell us more.
Old Apr 20, 2005 | 01:35 PM
dr_latino999's Avatar
Default Re: y wont my VTEC engage? D15B (drdisco69)
Is it wired properly (and by properly I mean OBD-1)?
Old Apr 20, 2005 | 01:58 PM
where can i find ot if my car has been converted to obd-1 ?
Old Apr 20, 2005 | 02:11 PM
ILLCRXSI's Avatar
pull up the carpeting and check the ecu, or check the distributor, if it has td-42u stamped on it than it has an obd1 conversion.
Old Apr 20, 2005 | 02:13 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I_love_my_HONDA &raquo;</TD></TR><TR><TD CLASS="quote">where can i find ot if my car has been converted to obd-1 ?
Check for your ecu. It should something like xxxx-P08-xxx (or P28). That would mean its obd-1 ecu. If its xxxx-PM6-xxx (or PG7 or PM7), then its obd-0. Just tell us what those 3 numbers/letters are and we will be able to tell if you are obd-1 or not.
If you are obd-1 then there are a few things that are stopping you from going into vtec. You need to be going over 20 mph (v.s.s. would be the culprit), you need sufficient oil pressure (check the pressure switch), and the engine needs to be up to operating temperature.
If you are obd-0 then you need something to activate vtec like an apexi vafc, msd rpm switch, etc.
Old Apr 20, 2005 | 02:15 PM
Mach69's Avatar
Default Re: (ILLCRXSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILLCRXSI &raquo;</TD></TR><TR><TD CLASS="quote">pull up the carpeting and check the ecu, or check the distributor, if it has td-42u stamped on it than it has an obd1 conversion.</TD></TR></TABLE>
He can check the distributor, td-42U would mean obd-1. Also, If you tell us that code stamped on the distributor arm, we will be able to tell if you are obd-1 or not.
Old Apr 20, 2005 | 03:40 PM
ServiceAdvisor's Avatar
Gibby? Maybe its just weak and you can't feel it . You should bring that Jalopy to my house and let me check it out for your, and give me my stock corner lens! - Darrell
Old Apr 20, 2005 | 04:33 PM
Its me DUB's Avatar
Default Re: (DOHCZCCRXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">Gibby? Maybe its just weak and you can't feel it . You should bring that Jalopy to my house and let me check it out for your, and give me my stock corner lens! - Darrell</TD></TR></TABLE> yup if you have stock corner lenses, your can can not efficiently reach vtec.
do what the guys said and get back with us....and give darrell your lenses dude!
Old Apr 20, 2005 | 09:31 PM
dARREL U PIECE OF **** COME OVER TO MY HOUSE OR CALLL ME U *** HOLE I TRIED CALLIN U AFTER U LEFT ME THAT MESSAGE MAYBE UR DOHC ZC KNOWLEDGE CAN HELP ME WITH MY SOHC VTEC PROBLEMS LOL
shiroun
Feb 26, 2012 06:57 PM
kuso1
Jul 3, 2006 03:40 PM
CiViC SiR
Oct 7, 2003 09:02 AM
