PR4 Vtec ecu for b18a1
Old Feb 25, 2012 | 05:38 PM
shiroun's Avatar
Default PR4 Vtec ecu for b18a1
Quick question.
Will a pr4 (VTEC) obd1 ecu work for a 1992 b18a1 swap into a 1990 honda civic hatchback (with obd0 to obd1 conversion)?
Old Feb 25, 2012 | 07:11 PM
Tim1982's Avatar
Default Re: PR4 Vtec ecu for b18a1
It will throw codes. But a 1992 civic should already be obd1.
Old Feb 26, 2012 | 05:04 AM
shiroun's Avatar
Its a 1990 civic, but a 92 b18a1 (which is obd1).
Is there a better ecu to use?
Old Feb 26, 2012 | 09:42 AM
civickiller's Avatar
pr4 vtec ecu? has a vtec kit been added?
obd1 pr4 is made for the obd1 b18a
Old Feb 26, 2012 | 03:08 PM
shiroun's Avatar
It was chipped. I'm assuming thats what did it?
Old Feb 26, 2012 | 03:20 PM
Dc4LsTeG's Avatar
EK9
Are you sure its chipped?and you sure it's vtec?
Old Feb 26, 2012 | 03:24 PM
shiroun's Avatar
He said it was using for a b16a, and it "popped" (engaged vtec) at 4500 RPMs. Apparently it was chipped for no rev limit
Old Feb 26, 2012 | 03:25 PM
Dc4LsTeG's Avatar
EK9
Have you tried using it in your car yet?
Old Feb 26, 2012 | 04:37 PM
you can cut the j1 jumper so its running off the stock map
Old Feb 26, 2012 | 06:57 PM
cloudconnected85's Avatar
If its an ls ecu, vtec is only looked for on the chip. cut the jumper for the chip and run it factory.
lol what he said^
hybridmiklo
Mar 7, 2009 08:12 PM
A-
Jan 8, 2008 02:25 PM
ej8
Oct 29, 2006 10:46 AM
bossman032
11
Dec 14, 2004 10:04 PM
Project92Hatch
Apr 17, 2003 10:52 AM
