Aluminum Radiators For MT Only...Why?
Old Apr 20, 2005 | 07:47 AM
NorcalHB94's Avatar
Default Aluminum Radiators For MT Only...Why?
My OEM radiator has a really really bad leak so i was looking around at aluminum radiators as a possibility for a replacement.
My car is an auto and all the ones i see say for MT only...why is this? is the AT larger? will it not fit? different valves on the radiator?
Old Apr 20, 2005 | 07:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Aluminum Radiators For MT Only...Why? (NorcalHB94)
The radiator for automatics has places at the bottom to run coolant through the transmission i believe, but other than that, they should be the same.
Old Apr 20, 2005 | 07:51 AM
5thGenCivicKid's Avatar
On a automatic there are 2 more taps on the raidator for the tranny thats y
Old Apr 20, 2005 | 08:17 AM
NorcalHB94's Avatar
Default Re: Aluminum Radiators For MT Only...Why? (5thGenCivicKid)
is it needed? will the tranny **** up without those taps?
Old Apr 20, 2005 | 08:36 AM
Kyles ej1's Avatar
no its not needed and not it wont **** up w/out em. i got that and all my friends got them too and we all have manuals.
Old Apr 20, 2005 | 08:37 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorcalHB94 &raquo;</TD></TR><TR><TD CLASS="quote">is it needed? will the tranny **** up without those taps?</TD></TR></TABLE>
The extra taps are to assist with additional cooling due to the AT....
Old Apr 20, 2005 | 08:43 AM
NorcalHB94's Avatar
Default Re: Aluminum Radiators For MT Only...Why? (DJ_SaNdOz)
yeah, what i'm asking is without those additional cooling taps...will the AT mess up?
FOC-US2K's Avatar
When my car was auto I had a fludyne radiator and trans cooler on there. You have to get the trans cooler or you risk over heating your trans. I still have the fludyne trans cooler left over from my swap. If you want it pm me...
Old Apr 20, 2005 | 09:11 AM
NorcalHB94's Avatar
Default Re: Aluminum Radiators For MT Only...Why? (FOC-US 2K)
oh you can get a AT cooler seperatley? that's good to know...will the fluidyne trans cooler only work with the fluidyne radiators or is it universal?
Old Apr 20, 2005 | 03:31 PM
Phoenix Fire's Avatar
Had the same problem as you. Radiator was leaking on the top (crappy plastic tops) so i bought an 2"inch think aluminum Radiator for $189 shipped! Thinking that my problem was solved. Found out it was only for manual, which does not have the oil cooler transmission for the two lines I need. Found out that you need the oil cooler or you risk the chance of overheating your trans fluid. Found out it can been done! Just to have fabricate your two lines to an oli cooler. Go dwn to Kragen, Autozone, etc... Buy an Oil cooler transmission, runs about $50 bucks. Come with everything you need in the box. Place the item infront of your radiator, which i did. Fitted perfect, or you can run in it the back of radiator, if you don't use your stock fan. Works great for me, No more plastic radiator, and my oil lines are cooled faster with it in the front. With an nice big 2"inch aluminum radiator!
Old Apr 20, 2005 | 03:43 PM
Purple_Civic's Avatar
just a get a tranny oil cooler
Old Apr 20, 2005 | 03:58 PM
NorcalHB94's Avatar
Default Re: Aluminum Radiators For MT Only...Why? (Purple_Civic)
good to know, thanks for the tips
Old Apr 22, 2005 | 07:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Purple_Civic &raquo;</TD></TR><TR><TD CLASS="quote">just a get a tranny oil cooler</TD></TR></TABLE>
It depends on what kind of radiator you are going with? Some radiators have the oil cooler in it already, like the OEM radiator. Aftermarket ones, depends. If going the way I did, then yeah! Your good to go.
Charlie Moua
Apr 26, 2023 02:47 PM
escape2me
Apr 10, 2006 08:46 PM
RICE POLICE SIP
Apr 29, 2005 08:12 AM
NAgixxer
Feb 9, 2004 07:09 PM
Artful Dodger
Jul 7, 2003 09:21 PM
