Trick: Start car without using clutch pedal...
If you wanna start your crx or civic without pushing the clutch pedal, at the top of the clutch pedal assembly, there is a switch... just disconnect it , and voila.. you can start the car without the clutch ! It's kinda hard to get to though....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I don't even need to do that on my 88 crx.
WOOT
</TD></TR></TABLE>WOOT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S »</TD></TR><TR><TD CLASS="quote">88 Civics and CRX's did not have that switch
Just be damn sure that the car is in neutral
This is very useful when you are working on the car and don't want to get in. Some of my friends were surprised
You can also do it on 2g dsm's
</TD></TR></TABLE>This is very useful when you are working on the car and don't want to get in. Some of my friends were surprised
.You can also do it on 2g dsm's
any tranny can do it. all you got to do is match RPMS. 4k rpms usually next gear will be around 2k rpms(depending on gear ratio). when you are around 2k shift from neutral into next gear. if you get the timing right it'll slide right in. works for downshifting too(use reverse instruction, just rev up to match rpms)
Shifting without the clutch is fine. Truck drivers do it all the time because they have so many gears and ****. My buddie has his cdl and was taught and drives with out using the clutch except for first gear. As long as the rpms are right it will just fall right into gear.
yeah my brother's dad is a truck driver and he taught me to do this, he also says it is not bad for the tranny just match the rpm's, just don't go trying to jam it in gear, because that is bad for the tranny. I do it sometimes when I am bored, what is really hard is downshifting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloweredcivic »</TD></TR><TR><TD CLASS="quote">why would you want to be able to start it without the clutch i have seen so many cars that have been ran into stuff because people just forget</TD></TR></TABLE>
Because here at HT, we're lazy SOBs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by west nile »</TD></TR><TR><TD CLASS="quote">yeah my brother's dad is a truck driver and he taught me to do this, he also says it is not bad for the tranny just match the rpm's, just don't go trying to jam it in gear, because that is bad for the tranny. I do it sometimes when I am bored, what is really hard is downshifting.</TD></TR></TABLE>
ITS kool to not shift without a clutch..........it also came in handy when my clutch cable snapped one time and i was about 10 miles away from home.......just gotta be careful @ lights and interSECTIONS came in really handy 4 me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-crx »</TD></TR><TR><TD CLASS="quote">
WOOT </TD></TR></TABLE>
double WOOT
double WOOT
Rob.
39
Aug 25, 2006 08:10 PM
99cpevtec
Jul 15, 2005 02:27 PM
