Air Fuel Gauge gone wack - WTF?
Old Apr 19, 2005 | 11:03 PM
athoughts's Avatar
Default Air Fuel Gauge gone wack - WTF?
HT...
Car is running fine and everything is normal, i go into KFC to eat with some friends.
I come back out and start my car and my AF gauge is wayy wack, i know its not accurate without a wideband, but it dosent look like this..
I made a quick picture of what it looks like in photoshop,
You guys know how the normal AF gauge is, it dances around, well mine used to.. it is now split in like 2 and locked.. doesnt move???
any suggestions on wtf is going on?
thanks
EDIT: ok it now doesnt work at all.. ideas?
Modified by athoughts at 12:23 AM 4/20/2005
Modified by athoughts at 5:48 PM 4/21/2005
Old Apr 19, 2005 | 11:22 PM
athoughts's Avatar
Default Re: Air Fuel Gauge gone wack - WTF? (athoughts)
Old Apr 20, 2005 | 04:08 AM
Myh4tch's Avatar
wtf mate.... you traced the wires down to the o2 to see if anything came loose? Possibly shorted? Wow thats wierd as hell...
Old Apr 20, 2005 | 04:17 AM
137's Avatar
137
Default Re: Air Fuel Gauge gone wack - WTF? (Dawn Dreaming)
probably shitty install work to get cool parts in your car, that seems to be the case with mose electrical failures.
Old Apr 20, 2005 | 05:18 AM
MikeD718's Avatar
Default Re: Air Fuel Gauge gone wack - WTF? (137)
i would check all the wiring before anything
Old Apr 20, 2005 | 05:40 AM
athoughts's Avatar
Default Re: Air Fuel Gauge gone wack - WTF? (MikeD718)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 137 &raquo;</TD></TR><TR><TD CLASS="quote">probably shitty install work to get cool parts in your car, that seems to be the case with mose electrical failures. </TD></TR></TABLE>
could be the case but its been a year with no problems, and one wack night
so pretty sure thats not the case
Old Apr 20, 2005 | 05:53 AM
revvin9k's Avatar
Same thing happened to my Autometer A/F gauge, junk it and get a wideband.
Old Apr 20, 2005 | 06:26 AM
Si Shane's Avatar
Default Re: Air Fuel Gauge gone wack - WTF? (S(J)O(D)L(M))
that gague offers you NO real information.
Old Apr 20, 2005 | 06:47 AM
EE_Chris's Avatar
Default Re: Air Fuel Gauge gone wack - WTF? (Si Shane)
If it uses the LM3916, which just about all of these narrowband a/f gauges use, then the chip is probably bad.
All the thing does it take a voltage (0-1v in the case of the O2 sensor) and light up the LED's - so if more than one light is lit up (and its in dot display), then the chip is probably bad.
Old Apr 20, 2005 | 02:29 PM
athoughts's Avatar
Default Re: Air Fuel Gauge gone wack - WTF? (EE_Chris)
well during my drive to school today, it randomly started working again, who knows whats up with it,
thanks
Old Apr 21, 2005 | 04:48 PM
athoughts's Avatar
ok now its stop working again
Old Apr 21, 2005 | 05:11 PM
clutcher's Avatar
Maybe it's time for a new oxygen sensor?
Maybe the sensor is shorting?
Why don't you measure the voltage you get at the sensor and then at the gauge and see if there's any difference between the two and if they're within the spec...
could also be a bad gauge but i would first check your O2 sensor...
Old May 5, 2005 | 11:14 PM
athoughts's Avatar
Default Re: (clutcher)
alright, so its raining tonight here in san diego, and its been about 2 weeks with a working AF gauge.
Its now stoped working again, ramdomly shut off. ..
Old May 6, 2005 | 12:40 PM
Accel Junky's Avatar
Those things give a general idea on AF.
If it gets bouncy its usually during idle or part throttle.
Old May 6, 2005 | 12:42 PM
Status Sean's Avatar
Default Re: (athoughts)
its either a loose connection or your o2 censor went bad !
Old May 6, 2005 | 02:04 PM
Leb_CRX's Avatar
Default Re: (rw92civic)
if the o2 went bad he should be getting a CEL
make sure it's connected properly, so what it's been a year working, it aint now, so check it
Old May 6, 2005 | 02:08 PM
EJ1 wilcox's Avatar
Default Re: (Leb_CRX)
Sounds like some kind of electrical short...
Put up with it for a few months, Autometer is coming out with a gauge type wideband that sould be in the $300 range.
Old May 6, 2005 | 03:18 PM
menkio's Avatar
Default Re: (EJ1 wilcox)
lol !!!!
Old May 6, 2005 | 03:33 PM
mengo_charged's Avatar
Default Re: (menkio)
I've heard that O2 sensors don't ALWAYS give you a CEL. Borrow a known working one from a friend and see what happens...
wrEcKed_LX
Apr 26, 2005 03:56 PM
IggDawg
Feb 8, 2004 04:06 PM
phazeshifter
Nov 5, 2002 06:09 AM
phazeshifter
Nov 4, 2002 08:50 AM
phazeshifter
Nov 4, 2002 07:25 AM
