Still having trouble!! PLEASE HELP!!!
Im still having trouble with my VTEC not coming on!! Im gonna tell me setup once again.
d16z6 bottom end bored .010
Eagle Rods
SRP Pistons (10.5:1 CR)
d16y8 head milled .010
ZEX valve springs
TI retainers
ZEX 105300 (Stage 2)
What i have done so far:
Checked oil pressure (good)
Checked solenoid (good)
Converted to obd1 (still didnt fix problem)
Changed cam (i use to have a d16z6 cam, now i have a d16y8 cam, this still didnt fix problem)
Checked rocker arm assembly and little pistons (good)
What else is there to check? Should i pull the head off and check something there? If so what? Someone help me out please!!!!
Eagle Rods
ZEX valve springs
TI retainers
Needs to be About 20% Cooler
any codes?
for computer actavation it takes:
oil presure (the swich by the soloioid)
car moving >25 mph. (VSS)
and car warmed up (ECT >~180F)
well i took the cam out and rocker arm assembly off and activated the solenoid and turned the motor over, and oil is shooting out of the middle hole where the rocker arm assembly bolts to. When i dont activate the solenoid the same amount of oil comes out. What could be wrong?
Genos D16
Jul 4, 2019 08:24 AM
Hank!
Jul 10, 2008 07:42 AM
