Power Window Switch
Driver's side switch seems to be intermittent in operating the window. Has anyone had this issue? It will always go down, but will intermittently go up.
I thought about taking the switch apart and cleaning the contacts w/ a cleaner.
Is there anything else that I should be checking???
Sweet, think I fixed it. It just needed the contacts cleaned (pickup a contact cleaner at any radio shack). I was cheap and only picked up the contact pen which should be around $3.
Checked the continuity per the Helms. This is for the left side master switch. If you look at the switch (blades facing you with 4 blades on top and the 6 on the bottom), label them as:
A B C D
E F G H I J
Driver's Window:
With the switch in the Off position, there should be continuity between Terminals H, I, and J.
With the switch in the UP position, there should be continuity between terminals C and J. Also check between terminals H and I.
With the switch in the DOWN position, there should be continuity between terminals C and H. Also check between I and J.
Passenger's Window:
With the switch in the OFF position, there should be continuity between terminals A, B, and E (with the master switch in the ON position. With the master switch in the ON position, there should be continuity between A and B.
In the UP position and master switch in the ON position, there should be continuity between B and E. Also check between A and F.
In the UP position and master switch in the OFF position, there should be continuity between A and F.
In the DOWN position and master switch in the ON position, there should be continuity between A and E. Also check between B and F.
In the DOWN position and master switch in the OFF position, there should be continuity between B and F.
A B C D
E F G H I J
Driver's Window:
Passenger's Window:
BlueIntegraBoy
Apr 14, 2008 10:23 PM
