tranny noises????
Old Apr 19, 2005 | 10:40 AM
CaptinMcnut's Avatar
Default tranny noises????
ok i have a 94 del sol with a d16z6 and whenever i start off the tranny make no noises but whenever i reach about 2000 rpm in every gear it makes this kinda of gear winding noise i figure its some sort of bearing inside the tranny maybe on the countershaft cause it only does it in gears under power not in neutral when coasting i dont know any help is appericated???
Old Apr 19, 2005 | 10:51 AM
Default Re: tranny noises???? (D94sol)
bump
Old Apr 19, 2005 | 11:20 AM
JDM-EJ1's Avatar
Is it a manual or automatic..
You said in 'every gear' so I'm assuming it's a manual. I had an auto tranny and when my card made that 'windy' noise it went out.
Old Apr 20, 2005 | 09:28 PM
Default Re: tranny noises???? (JDM-EJ1)
yah its a manual and bump
Old Apr 20, 2005 | 09:56 PM
allmotorEG-SI's Avatar
mine just did the same thing. i just replaced the tranny for $200 + my weekend. It wasn't hard just time consuming. mine did what yours did but then started grinding and killing my gas milage. try soome new honda mtf and see if that helps first befor u do anyhting,
civiccoupe94
Honda Civic (2001 - 2005)
Nov 11, 2007 11:59 AM
Miniman253
May 21, 2005 08:36 PM
invboost
11
Apr 2, 2004 06:08 PM
