crx boggs after getting off interstate...
Old Apr 19, 2005 | 10:09 AM
christianscrx's Avatar
Default crx boggs after getting off interstate...
I can fiqure this out. My b16 a couple of times bogs down as soon as i get off the interstate. It accelerates and drives around town fine. But as soon as I get off and stop then go give it some gas it bogs almost like im not getting no throttle responce. I was thinking fuel pump but it hardly does it? Any ideas?
Old Apr 19, 2005 | 10:14 AM
jester's Avatar
Default Re: crx boggs after getting off interstate... (christianscrx)
Are you throwing any codes?
Check to see if you are.. under your floor mat on the passenger side you will see it . There is a thread on here about how many light beeps=what. It may be your tps sensor
Old Apr 19, 2005 | 10:31 AM
crex23's Avatar
Default Re: crx boggs after getting off interstate... (jester)
Bump for you. My car is doing this too, it bogs and stutters bad at idle and when I give it gas. I've talked to a few people who suggested replacing the oxygen sensor, but I have no codes.
Old Apr 19, 2005 | 10:36 AM
2kTeg's Avatar
check your throttle body and make sure your butterfly is opening/closing normal.
Old Apr 19, 2005 | 10:37 AM
d16efsedan's Avatar
Default Re: crx boggs after getting off interstate... (crex23)
sounds like a 02 sensor to me mine does the same thing.....
Old Apr 19, 2005 | 11:50 AM
no codes...Im only running one 02 sensor. But never had the problem after i complete the swap with only running one 02 sensor
Old Apr 19, 2005 | 01:25 PM
1point5CRX's Avatar
Default Re: (christianscrx)
mine did that sort of thing, i actually bumped up the fuel pressure on the regulator and backed my timing down a tad, it cleared right up.
Old Apr 19, 2005 | 02:00 PM
Default Re: (1point5CRX)
I think i fiqured it out... my o2 sensor wasnt even plugged in it was discontected!
Old Apr 19, 2005 | 02:07 PM
dr_latino999's Avatar
There was a nice write-up on why you should run two O2 Sensors and the Lamda logs that back it up. When I get back to my room I will find it.
Old Apr 20, 2005 | 08:29 AM
why wouldnt it have thrown a code if the o2 sensor isnt plugged in????? The check engine ligh does work.
airikkCRX
Apr 25, 2010 11:23 AM
geogal84
Oct 23, 2007 02:41 PM
deucedeuceEK
Apr 27, 2007 02:39 PM
shutta
Apr 5, 2007 04:46 AM
turboxsi
Jun 16, 2003 08:13 PM
