Changing Manule Tranny Fluid?
Old Apr 19, 2005 | 09:14 AM
aoe_virus's Avatar
Default Changing Manule Tranny Fluid?
I don't see any small dipstick or nothing on the tranny. Where do I drain and fill it back up at? 1995 Honda Civic EX. d16z6 engine.
Edit: I did some more searching and found a couple thread in the FAQ and they say do it througth the VSS, easy enough. So I guess all I need to know is where the drain plug is (probably on the bottom somewhere), and what fluid do I need?
Modified by aoe_virus at 10:27 AM 4/19/2005
Old Apr 19, 2005 | 09:27 AM
pdiggitydogg's Avatar
Drain is obviously the one with fluid coming out:
The upper one, near the axle, is the fill - but its easier to fill from the vss at the top:
Searching would have led you to this:
https://honda-tech.com/zerothread?id=382416
Old Apr 19, 2005 | 09:28 AM
aoe_virus's Avatar
Thank you.
Old Jun 20, 2005 | 10:50 AM
the.hamburglar's Avatar
Default Re: (aoe_virus)
where is this vss at the top? im changing my tranny fluid soon. what should i use?
Old Jun 20, 2005 | 10:51 AM
Default Re: (hamburgler)
i have a b16 if that makes any difference
Old Jun 20, 2005 | 11:00 AM
D15Bbigred's Avatar
reg motor oil, call honda, or search....
Old Jun 20, 2005 | 11:18 AM
Default Re: (EG1racer)
yeah honda has some special tranny fluid. what about this vehicle speed sensor? where abouts is it located?
Old Jun 20, 2005 | 11:19 AM
staticrex's Avatar
You should still open up the fill bolt so you can get the right amount of fluid in there. Filling through the VSS you could possibly put in too much.
Just get a funnel with a long tube.
Old Jun 20, 2005 | 11:57 AM
GetawayInMoscow's Avatar
I thought 5w30 motor oil is sufficient for the tranny?
Old Jun 20, 2005 | 12:24 PM
dpkelly's Avatar
Default Re: (GetawayInMoscow)
10w30 is recommended. But you should use the manual tranny fluid. Never fill from the vss since it may get damaged and you may overfill the tranny. You may need a breaker bar on those bolts. Good luck.
Old Jun 20, 2005 | 12:58 PM
Deemeetree's Avatar
Electrician
Go to AutoZone and pick up a few bottles of Pennzoil Synchromesh. Then, call it a day.
I never use the VSS to fill. I just remove the filler plug and use a long tub connected to a funnel. Fill her up and wait until the fluid dribbles out. Done.
Old Jun 20, 2005 | 05:57 PM
Default Re: (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly &raquo;</TD></TR><TR><TD CLASS="quote">10w30 is recommended. But you should use the manual tranny fluid. Never fill from the vss since it may get damaged and you may overfill the tranny. You may need a breaker bar on those bolts. Good luck. </TD></TR></TABLE>
Is this for sure? Can someone confirm this?
Old Jun 20, 2005 | 06:05 PM
Deemeetree's Avatar
Electrician
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">Is this for sure? Can someone confirm this?</TD></TR></TABLE>
Confirm what?
10w30? Just use Manual Transmission Fluid.
Damaging the VSS? Only if you're careless or don't know how to turn a ratchet.
Overfilling the tranny? That's why you leave the fill plug OFF, so when it reaches that point, it'll dribble out.
Breaker bar? No, I've only used a 1/2" drive ratchet on my bolts, came off easily.
em12nv
Feb 9, 2008 01:49 PM
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
kornerk12
Nov 18, 2005 05:37 AM
2k1_ITR_0736
Jan 28, 2003 06:37 AM
pelotudo
Jul 21, 2002 02:33 AM
