b16a3 cutting out after 3500 rpms ? ? ?
My friends got a 94 del sol with the b16a3. We got a new dizzy for it and after installing it the car ran fine. But about three minutes later we would hit 3500 rpms and it wouldnt rev any higher. It sounded like a rev limiter and then we would have to shift. What is that? It never did it with the old distributor. Anything would be helpful.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 »</TD></TR><TR><TD CLASS="quote">Sounds like its in limp mode.</TD></TR></TABLE>
in our hgh school autos we did a swap in a del sol with a b16a2 i believe and it fixed the prob..... for us
Edit: forgot the crank shaft pos. sensor, sorry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_project98 »</TD></TR><TR><TD CLASS="quote">in our hgh school autos we did a swap in a del sol with a b16a2 i believe and it fixed the prob..... for us
How does that help whatsoever?
</TD></TR></TABLE>How does that help whatsoever?
How does that help whatsoever?</TD></TR></TABLE>
Edit: forgot the crank shaft pos. sensor from doing the swap, the harness prong got broke, and it only allowed the car to run up 2400 rpm replaced the harness fixed the prob
The motor is already in the car, and has been, he just replaced the distributor, what does the CKP sensor have anything to do with anything?
the other day i put new plug wires on and i accidently misplaced 2 of them in the wrong spot causing 3 and 4 to not run...my b16 ecu just ran up to 3500 like you said...easy mistake..check it out...still doesn't explain on it running good at first tho..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSOLEMITE »</TD></TR><TR><TD CLASS="quote">disconnect the battery and then reconnect to reset everything, might help...</TD></TR></TABLE>
when in doubt disconnect that battery. Just make sure if you radio requires a radio code, thaty ou have it otherwise u gotta go to honda and they have to find out what it is
I forget
Jan 6, 2004 02:33 AM
