7 psi from turbo?
I am looking to hit 12's in my 04 SI... it's a 5 speed and I got drag radials, full exhaust, and intake... You think a turbo running 7psi could get me where I need to be for high hoping for a high 12? Turbo or S/C... whatever works better on these motors.
there are too many other factors, what kind of turbo, are you just using a kit or building your engine too. You'll need pistons, rods, injectors, sleeved block, EMS and 7 psi isent alot so you'll need more of a plan than that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChrisUlrich »</TD></TR><TR><TD CLASS="quote">Nah, just a turbo kit. It would be 7 psi on a turbo, intake, and turbo back exhaust... thats it. Stock internals... oh yea and BFG DR's</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystar »</TD></TR><TR><TD CLASS="quote">maybe if u had a K20A2 on 7psi. but u only have a K20A3. sorry </TD></TR></TABLE>
WOW, that is harsh.
WOW, that is harsh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by giff74 »</TD></TR><TR><TD CLASS="quote">WOW, that is harsh. </TD></TR></TABLE>
he speaks of the truth. i still doubt with a k20a2 and 7psi will get him into 12's...
if he is shooting for 12's..he needs to run a lot more than 7psi and that is going to require a sleeve piston rods job..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy »</TD></TR><TR><TD CLASS="quote">
if he is shooting for 12's..he needs to run a lot more than 7psi and that is going to require a sleeve piston rods job..</TD></TR></TABLE>
There are some boosted DC5s and EP3s that run in the 12s with stock internals (check crsx and ephatch). Mind you, this is at well above 7 psi....
even if he had the k20a2 on 7psi, it won't yeild 12's. I was running 10psi and was getting 301whp and 255wtq on my k20a3 in the si. I couldn't hit a 12 due to traction...even with lsd. I was hitting 13.3@110mph. Hit a 13.4@113mph once also. The mph was there, the 60fts and 1st to 2nd shift were a big traction loss.
What kind of boost can an 04 Si run off a Turbo/Supercharger safely?
My friends "Claims" that his friend with his 04 SI ran a 12.3 with nothing done except, intake, exhaust, and turbo boosting to 10 psi... 3 runs then BOOM... but 12.3? Man that seems shady to me.
