Chipped Ecu (difference in hondata, Neptune, uberdata etc..)????
I been reading up extensively on tuning and ecu chipping...my question is because i didnt run across it while researching is...Can you use the same Chipped ecu for lets say Uberdata and use it on hondata for example or do you have to modify it? If not what minor differences are there b/w chipped ecu's for crome, uberdata, neptune, and hondata (besides the blue box
I had a freind send in his ecu which was chipped for hondata to convert to neptune? so i just wondering what adjustments to they make? Thanks
)I had a freind send in his ecu which was chipped for hondata to convert to neptune? so i just wondering what adjustments to they make? Thanks
I spoke with superdave from whip factory and he told me yes. I had one chipped for hondata and I was told that I can use it for neptune.
You will need to add the 4 pin interface wire for the Hondata cable. That is not needed for some of the other softwares.
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
