V-Band 2.5" to 3" adapter plate?
Who makes this?
and possibly better yet:
I have heard that the v-band flange on the hot side of the Holset HX35's is not quite exactly 2.5 inches. . . .something a little larger or smaller, not sure which.
Does anyone make an adaptor to go from the Holset hot side that flares out to 3" vband?
Thanks in advance fellas
Go to a local trucking(diesel) store and take the turbo with you. They should be able to hook you up with the correct flange. It may be mild steel but, it works. Ask me how I know
. Good luck
Phil
. Good luckPhil
I'll give that a shot. . . if that's a no go I'm going to hit the AutoJet factory. . . they gotta have some kind of a flare or something that won't end up jank looking/performing.
Thanks man. Much appreciated.
ATP Turbo has few V band flanges as well. You can try them but, the trucking parts store is still your best bet. Especially since I have seen many Holeset's on Perkins/John Deere diesels. What is Auto Jet?
Phil
Phil
AutoJet is a local company out in Iowa that manufactures piping and flanges.
Don't know if they have any flair tubing or anything.
There are several trucking parts stores I can check though. Hopefully at one of them I can find the exact part I need.
Thanks again hondaguyef
