Help Reading my Dyno
Forgive me for my inexperience with reading dyno sheets, but bellow is my most recent dyno from the setup below. Could someone help my analys it in terms of optimum shift points and launch points? Any other info would be greatly appreciated so I can further my knowledge in this area. Thank You.
Launch between 6,000-6,200 rpm's (drag radials). Street tires, launch at a lower rpm and slide the clutch (preload). Shift around 8,000-8,200 rpm's. By the way great results after tuning. At first, you were running way too lean! You will definately notice an improvement in your 1/4 mile times, assuming that you are a decent driver
good luck. let us know your times once get back from the track.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">Shift: 8200 looks to be optimum to me.
Launch: Depends on tire size/compund (slick, D/R, street) and track prep.
Phil</TD></TR></TABLE>
Tires are nitto 450 205/50/15 not great but if u heat them up a bit i have been able to stick 2.2 60fts, but i should be able to do better and the track is Sacramento Speedway. I'll be out the tomarrow night for wed night fun runs
Also one other question is it possible to slip the clutch with hondatas launch control?
Schister66
Jun 3, 2007 08:23 AM
riceball777
20
Oct 3, 2005 09:07 AM
