Help, getting a turbo for a b16a (.63 x .48)
Hi All, i'd like to know, in what rpm(aprox.) wich setup get full boost. (6psi)
- 802122 T3/TO4E TURBO
EX: T3 49,5 RT: TO4E 52,5
(turb).48 (comp).50
- 802125 T3/TO4E TURBO
(turb).63 (comp).50
Both using 6psi. Stock b16a + Intecooler.
I Know, that it's impossible to get a exactly value, but, just I idea, because i'm between them. As I live in BRazil, and these are some kind of turbo that I can get for a resonably price. (Sorry for my bad english)
THanks!
(turb).48 (comp).50
(turb).63 (comp).50
THanks!
Hi! Thanks for the replys!
Also, Can I use a .63 with AC? Because I don't know if there is enough room for the turbo, or can I use without any problem?? I'm going to use a custom Manifold....
Thanks again!
Thanks again!
Hi All. So, I'm going .63
But I have found this one too:
810021 T300/TO4E TURBO EX. HIGH-PERFORMANCE TO E.U.A
EX: T300 56 RT: TA 58,16
INLET T3 .63 OPEN .50 VOLUTE
This is the other one....
(turb).63 (comp).50
As I can see, the main diference are the wheels size, so, i'd like to know, wich of them would be better? What are the pro/con of using bigger wheel in the same house? Ah I don't know too what "HIGH-PERFORMANCE TO E.U.A" mean, do you do?
Thanks again!
(turb).63 (comp).50
Thanks again!
