Thrust Washer problem (fell out)
Old Apr 18, 2005 | 01:48 PM
milano2kdc2's Avatar
Default Thrust Washer problem (fell out)
I took out my pistons yesterday, and this morning i noticed one of my thrust washers sitting on the ground, i know which one and where to put it, but i cant seem to get it in there!
how do i slide the thrust washer back in place without removing the crank?
i know it can be done cause if it fell out, there has to be a way to get back in there
thanks in advance for the help
Modified by milano2kdc2 at 1:33 AM 4/19/2005
Old Apr 18, 2005 | 02:40 PM
Default Re: Thrust Washer problem (milano2kdc2)
help help :[
Old Apr 18, 2005 | 04:34 PM
added pics
Old Apr 18, 2005 | 04:53 PM
NJIN BUILDR's Avatar
Default Re: (milano2kdc2)
There should not be anyway the thrust washers can "fall out" with the main cap on.If the thrust face on the crank is damaged or the thrust bearings are junk are the only ways they could fall out that I can think of.
Glenn
Old Apr 18, 2005 | 07:24 PM
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">There should not be anyway the thrust washers can "fall out" with the main cap on.If the thrust face on the crank is damaged or the thrust bearings are junk are the only ways they could fall out that I can think of.
Glenn</TD></TR></TABLE>
i took off 3 of the main caps along with the cap bridge to get to the connecting rod so i can push out the pistons
Old Apr 18, 2005 | 07:37 PM
nm got it! thx njinbuildr for replying
AllmotorEH2
Dec 28, 2009 12:35 PM
joshcuhz
Oct 25, 2007 11:31 PM
AllmotorEH2
Feb 23, 2007 04:40 PM
ekeddie
Jul 12, 2006 08:12 PM
milano2kdc2
Apr 18, 2005 01:49 PM
