D16Y8 compression?
Old Apr 18, 2005 | 12:05 PM
UA6 BALLER STATUS's Avatar
Default D16Y8 compression?
Right now my friend calls me and he asked me to go on H-T and find out what his compression should be. How much psi should it be at on a D16Y8 motor.
TIA.
Old Apr 18, 2005 | 12:07 PM
POE's Avatar
POE
u have been here for a while. do you ever search for your answer's?
Old Apr 18, 2005 | 12:09 PM
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">u have been here for a while. do you ever search for your answer's?</TD></TR></TABLE>
Yup but I need to know ASAP and I did searched but didn't find the answer im looking for and im searching as we speak. Thanks for nothing.
Old Apr 18, 2005 | 12:16 PM
Default Re: (Type SH)
He says he got 150 on all four pistons and the mechanic is telling him its normal and that's what it should be but my friend thinks otherwise and right now hes still over there and on the phone with me.
Old Apr 18, 2005 | 12:43 PM
AutoXer's Avatar
https://honda-tech.com/zerothread?id=1083730
Sounds like he may have done the test wrong. I did as well. Hold it WOT with all plugs removed. My comp numbers went from 150 to 210.
Old Apr 18, 2005 | 01:08 PM
honda_S's Avatar
no its not that im asking if those numbers are right its just my car feels like the compression is low and he says 150 is normal and i dont think it is the motor i had befor wich was the same felt way faster and responded better too
Old Apr 18, 2005 | 01:57 PM
n01stunna's Avatar
I heard the compression ratio on a d16y8 was 11:1 but i dont totally know i personally thought it was lower
Old Apr 18, 2005 | 02:06 PM
EK k kay's Avatar
Default Re: (n01stunna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n01stunna &raquo;</TD></TR><TR><TD CLASS="quote">I heard the compression ratio on a d16y8 was 11:1 but i dont totally know i personally thought it was lower</TD></TR></TABLE>
No way not 11:1. More like 9:6:1 or something of the like.
Old Apr 18, 2005 | 02:26 PM
NaVamous's Avatar
Compression should be around 180 to 190 on all four cylinders.
Old Apr 18, 2005 | 03:44 PM
honda_S's Avatar
what do i do to fix my compression
Old Apr 18, 2005 | 04:45 PM
AutoXer's Avatar
Default Re: (8y61d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8y61d &raquo;</TD></TR><TR><TD CLASS="quote">what do i do to fix my compression
Did you read the link that I posted? I got the same numbers (150) with my test, but I didn't do it at WOT. When I re-did the test, it came out to 210. 150 is an okay number for alot of motors, but Honda motors are pretty high compression, and 180 is a good number.
Is there something specifically wrong with your car that you had this test done in the first place, besides feeling sluggish?
The only way to 'fix' compression would be internal servicing, most likely rings. Read my liink to see if the mechnic did the test properly, because you may not have a compression problem at all.
Old Apr 18, 2005 | 10:42 PM
honda_S's Avatar
i blew my motor so compared to the one i had befor my new one feels more sluggish. now whether he did it right or wrong somthin is still wrong with my car so i dont care if he did it at wot
Unseen Racer
Oct 7, 2008 06:56 AM
white-ek
Feb 8, 2005 05:13 PM
00supercivic
Nov 30, 2004 08:11 PM
SpoonPoon
Nov 27, 2003 08:44 PM
