Tried to install VAFC...Check engine light on... no CEL..???
Old Apr 18, 2005 | 11:23 AM
NeriVTEC's Avatar
Default Tried to install VAFC...Check engine light on... no CEL..???
My friend was trying to install a vafc on his prelude and when he put the ignition switch on the check engine light was on and we checked for CELs and none came up...what coul be happening here because he took out the vafc (didn't splice any wires so the cables are intact) and the caro won't start now. Can somebody tell me what could be wrong?
Old Apr 18, 2005 | 01:20 PM
esca's Avatar
Default Re: Tried to install VAFC...Check engine light on... no CEL..??? (NeriVTEC)
you did something to the ecu while you were installing the vafc.. no cel blinks = ecu problem
maybe you didnt put all the wires together or something
Old Apr 18, 2005 | 01:38 PM
NeriVTEC's Avatar
we tested the ecu on another car... worked perfectly
Old Apr 18, 2005 | 05:08 PM
NeriVTEC's Avatar
anybody who can help please
Old Apr 18, 2005 | 05:37 PM
xbn83's Avatar
Default Re: (NeriVTEC)
Re-check all your VAFC wires, make sure you hook them up right to the ECU
Old Apr 18, 2005 | 05:42 PM
NeriVTEC's Avatar
Default Re: (xbn83)
he took out all the wires from the VAFC and doesn't want to install it he just wants to get the car to start.
Old Apr 18, 2005 | 05:43 PM
Sick'Lude's Avatar
Yea i put mine on myself and just this past week i was driving and it died it has NO spark i dunno what happened i dont think it was me ecu or vafc cuz its been installed over a month works like a charm
Old Apr 18, 2005 | 05:45 PM
NeriVTEC's Avatar
Default Re: (Sick'Lude)
but did you get it to start?
Old Apr 18, 2005 | 05:53 PM
Sick'Lude's Avatar
when i first installed it yes but the other day it jus died out i dunno wat it is, i have no spark at all..but double check your connection right make sure no wires are in the wrong place...
Old Apr 18, 2005 | 05:57 PM
NeriVTEC's Avatar
does the vafc turn on if the vtec wires are not connected?
Old Apr 18, 2005 | 06:31 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeriVTEC &raquo;</TD></TR><TR><TD CLASS="quote">he took out all the wires from the VAFC and doesn't want to install it he just wants to get the car to start.</TD></TR></TABLE>
So he took out the VAFC harness and try to start the car without VAFC? Did he reconnect all the wire that he cut from the ECU. Because when installing VAFC, you have to cut VTEC selonoid signal output, and Pressure signal output wires.
Old Apr 18, 2005 | 06:39 PM
NeriVTEC's Avatar
Default Re: (xbn83)
yeah he did put the wires back together
Old Apr 18, 2005 | 06:44 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeriVTEC &raquo;</TD></TR><TR><TD CLASS="quote">yeah he did put the wires back together
Does the engine turn over, trying to start? What yr is the Prelude?
Old Apr 18, 2005 | 07:04 PM
NeriVTEC's Avatar
Default Re: (xbn83)
yes it does ... its a 94 prelude...ecu is p14
Old Apr 19, 2005 | 06:57 AM
NeriVTEC's Avatar
Just found out the car has no spark at all and fuel pump is not activating...i think this is an electrical problem...???
Old Apr 20, 2005 | 05:58 PM
NeriVTEC's Avatar
Old Apr 20, 2005 | 09:32 PM
dmxsoulja3's Avatar
one word BOOMSLANG. stop whoring up your wiring, get the jumper harness, plug and play. 130 bucks now, or your car not starting for who knows what?
Old Apr 21, 2005 | 02:56 PM
JDMBB4's Avatar
Default Re: (dmxsoulja3)
Did you happen to mess with the ignition coil switch? If that isn't connected im pretty sure you wont get spark or fuel.
Old Apr 21, 2005 | 06:59 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeriVTEC &raquo;</TD></TR><TR><TD CLASS="quote">yes it does ... its a 94 prelude...ecu is p14</TD></TR></TABLE>
Hey, I just talked to one of my friend about this problem. I remember he had same problem b4. Check engine light on constantly, no code, no spark, no fuel. He figured out because the Map sensor wire got grounded somewhere. He fixed the problem. Make sure your buddy reconnected all the ECU wires good. Tape them up good also.
Inextricabledrvr
Feb 23, 2012 03:19 PM
SoldMyEM1
Apr 8, 2004 04:32 AM
Patch
Dec 10, 2003 04:09 PM
thehondaguru
Aug 12, 2003 08:54 AM
Nate B
Jul 10, 2002 04:10 PM
