How much whp are you running on your stock axles ???????
Old Apr 18, 2005 | 09:13 AM
376R's Avatar
Default How much whp are you running on your stock axles ???????
Im boosting in 3 weeks and dont really have enough to be buying some new stage2 axles. Im planning on around 300whp after tuning. Im wondering how much whp are you guys runnin on your stock axles, and if you go to the track with it. how is it.
Old Apr 18, 2005 | 09:30 AM
adseguy's Avatar
Default Re: How much whp are you running on your stock axles ??????? (klubhed1)
300whp should be OK. Limit your launches to when you need them
Hell a 600whp car can do with stock axels, it's really how you launch and if you launch with slicks.
Old Apr 18, 2005 | 09:36 AM
YiNYaNg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klubhed1 &raquo;</TD></TR><TR><TD CLASS="quote">Im boosting in 3 weeks and dont really have enough to be buying some new stage2 axles. Im planning on around 300whp after tuning. Im wondering how much whp are you guys runnin on your stock axles, and if you go to the track with it. how is it. </TD></TR></TABLE>
Just use ebrake & preload your clutch, it'll save your axels but your clutch will suffer...
Old Apr 18, 2005 | 09:54 AM
376R's Avatar
Default Re: How much whp are you running on your stock axles ??????? (H-T)
well i have pepboys axles in there right now... $99 for 2 new axles with lifetime warentee. cant go wrong. theyll work till i get $$ for stage 2's. i also got prothane poly motor mounts. that should help some
Old Apr 18, 2005 | 10:01 AM
Boostedcivicsi's Avatar
putting out around 380 whp on stock axles, 2000 honda civic, boosted with stock axles over 3 years now
Old Apr 18, 2005 | 05:21 PM
376R's Avatar
Default Re: How much whp are you running on your stock axles ??????? (Boostedcivicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostedcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">putting out around 380 whp on stock axles, 2000 honda civic, boosted with stock axles over 3 years now</TD></TR></TABLE> how hard to you launch , how much do you play around with it ?
Old Apr 18, 2005 | 05:28 PM
nfn15037's Avatar
336 whp and no axle issues either with stock axles. I have never launched it hard, all I do is autocross and do track days etc. Drag is teh weaksauce
Old Apr 18, 2005 | 06:19 PM
B00STED Si's Avatar
Default Re: How much whp are you running on your stock axles ??????? (nfn15037)
310fwhp and no axle issues, i figured they'd go first but the tranny did, i launch hard lol
Old Apr 18, 2005 | 06:25 PM
kabaroo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">336 whp and no axle issues either with stock axles. I have never launched it hard, all I do is autocross and do track days etc. Drag is teh weaksauce </TD></TR></TABLE>
you autocross with 336whp
Old Apr 18, 2005 | 06:37 PM
nfn15037's Avatar
Default Re: How much whp are you running on your stock axles ??????? (kabaroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo &raquo;</TD></TR><TR><TD CLASS="quote">you autocross with 336whp </TD></TR></TABLE>
On 225/45/15 Hoosiers up front w/LSD
Old Apr 18, 2005 | 06:55 PM
Dunc's Avatar
BCICAN
375whp
Old Apr 18, 2005 | 07:00 PM
DRIVENRacing's Avatar
450whp
Old Apr 18, 2005 | 07:02 PM
i really dont launch well off the line b/c of no lsd. i am running bfg radial tires, which hook up pretty well except for 1st and sometimes 2nd. when i do drive the car, i drive it hard, but only have 28,000 miles on it, only 15 of which were with boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klubhed1 &raquo;</TD></TR><TR><TD CLASS="quote"> how hard to you launch , how much do you play around with it ? </TD></TR></TABLE>
Old Apr 18, 2005 | 08:25 PM
Dunc's Avatar
BCICAN
same here. I have the bfg kdw-2's also. No lsd, so if I dump the clutch its around 3500-3800. If I feather it, its around 4000. all 23,000+miles have been boosted.
Old Apr 18, 2005 | 09:30 PM
376R's Avatar
Default Re: How much whp are you running on your stock axles ??????? (Dunc)
I have an 01 itr tranny w/ lsd with 205/50/15 bf goodrich ta drag radials i just dont wana snap
youdontneed2cams
Mar 5, 2008 06:10 PM
flatty
Suspension & Brakes
Mar 30, 2006 07:48 PM
turboman
Feb 20, 2006 11:40 PM
18gLUDE
Feb 8, 2004 09:26 PM
hybrid901
May 23, 2002 06:28 AM
