Has anyone had problems with Skunk2 cam gears chewing up cam keys
check this thread out Here.
As you can see, mine protrude the correct amount to be bolted down by the cam gear bolt. See if your cam gears protrudes further than the end of the cam so you know if the bolt its putting any pressure on it.
