JR's VTEC Controller
Old Jan 30, 2002 | 12:01 PM
subliminizm's Avatar
Default JR's VTEC Controller
Anyone use it? Is it worth it? Is 3500 RPM safe for a stock engine (on 97' lude)? Here's what I understand of the basic concept: You get to engage your VTEC much earlier than normal, and thus you would hit your peak HP much sooner. This doesn't add any HP, but it will allow you to accelerate a lot faster, because you reach peak HP quicker, thus making your lap times better. Sound right?
Old Jan 30, 2002 | 12:06 PM
Doctor CorteZ's Avatar
Default Re: JR's VTEC Controller (subliminizm)
nope - sounds wrong, 100 percent wrong
dyno - first run x-over all the way down
- secong run x-over all the way up
wherever they cross should be close to ideal
Old Jan 30, 2002 | 12:51 PM
Default Re: JR's VTEC Controller (Doctor CorteZ)
I am sorry, I don't quite follow you. Can you clarify what you mean, in lamens terms (I have never been to a dyno place)?
What benefit does the VTEC controller have? Or is it just a waste?
Old Jan 31, 2002 | 11:08 AM
wreckedagain's Avatar
you wont notice a difference unless you have cams, and you dont want to lower the v-tec engagement point that soon because you dont have enough oil pressure and it really won tdo any good, the v-tec controller is basically like a fine tuner you can change your fuel curve and engagement point to find out where lost hp is..
that's my theory at least
Old Jan 31, 2002 | 11:20 AM
Default Re: JR's VTEC Controller (wreckedagain)
Hey guys, thanks a bunch!! Your advice saves me $ and headaches. Thanks!!
Old Jan 31, 2002 | 11:22 AM
no problem
bb6_00
Sep 18, 2008 07:56 PM
tealsvteceg
Apr 22, 2008 07:20 PM
FlsFinest
Jul 21, 2005 01:33 PM
4doorex
Nov 17, 2004 06:43 AM
HYBRIDHATCH92
Mar 7, 2002 04:50 PM
