Question about IAB on LS VTEC in EG....
Old Apr 17, 2005 | 10:34 PM
Turbotype's Avatar
Default Question about IAB on LS VTEC in EG....
I cant figure out why it wont activate....I have the power in a17 on the GSR ECU and the ground tapped on A26....It still wont open up, and I dont know why...There is not CEL either, so im assuming the sensor on the box is still be read correctly......Im all out of ideas....
Old Apr 18, 2005 | 02:01 AM
RELprojects's Avatar
Default Re: Question about IAB on LS VTEC in EG.... (H22a N IT)
get a voltage meter and test the voltage from the ecu (black point on A26) and (red point on A17) do this with the ignition on ON position if you get voltage than its the wiring or the sensor and if you dont get anyvoltage then its your ecu
Old Apr 18, 2005 | 11:41 AM
Turbotype's Avatar
Default Re: Question about IAB on LS VTEC in EG.... (RELprojects)
I highly doubt its the ECU seeing as its practically brand new....Ill double check the wiring with the meter and see what happens, but I believe the wiring is correct and the sensor should be fine since it doesnt throw a light like it would if it were fried....
Old Apr 18, 2005 | 10:33 PM
Turbotype's Avatar
I figured it out...It was the stupid ECU pin....It wasnt going all the way into the harness, thus not making contact with the pin on the ecu....So I spent a lot of hours tryin to get my ONLY pin i had, manipulated to go on, but failed ....So i have to go and grab a couple more incase any others want to get retarded.....
bulgyh
Jun 27, 2015 08:12 PM
Zatzy
Oct 23, 2005 12:01 AM
Audipwr1
Jun 22, 2003 10:29 AM
