clean out the cat. convertor
Old Apr 17, 2005 | 09:43 PM
dayaftertomorrow's Avatar
Default clean out the cat. convertor
I took out the cat. convertor and see all clot inside. How do I clean it out. Need some help. Thanks
Old Apr 18, 2005 | 08:55 AM
drdisco69's Avatar
Default Re: clean out the cat. convertor (dayaftertomorrow)
If it looks like this:
It's time for either a new cat, or take a pry bar to that one and beat the insides out.
Old Apr 18, 2005 | 09:17 AM
4drmadness's Avatar
yeah if it's clogged normally people just gut them by ramming a rod through and knowcking away the clog and internals...Or buy a hi-flow cat or get a replacement OEM..
good luck...
Old Apr 18, 2005 | 05:35 PM
Default Re: (4drmadness)
Mine isn't that bad. Can I pour seafoam through to clean it? Thanks
Old Apr 18, 2005 | 05:49 PM
drdisco69's Avatar
Default Re: (dayaftertomorrow)
No. Why do people think that sea foam is The Uber Best Solution To Every Automotive Problem Ev4r? Get off it, there's better products out there, like GM or *gasp* Honda top engine cleaner.
I didn't mean to jump on you, I just see people jumping on sea foam for unfounded reasons.
Old Apr 18, 2005 | 06:10 PM
alpine_hikr's Avatar
Definately use honda top engine cleaner, i have used it before and it works great.
Old Apr 18, 2005 | 07:21 PM
v4lu3s's Avatar
RTFM
in the case of a cat you replace it.
it is NOT a service item that you can fix up.
Old Apr 21, 2005 | 09:14 PM
I just bought a used cat from junk yard. It has no clot but look dirty. How do I clean the inside? Thanks
Old Apr 21, 2005 | 10:47 PM
zacdaddy77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dayaftertomorrow &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a used cat from junk yard. It has no clot but look dirty. How do I clean the inside? Thanks</TD></TR></TABLE>
!!!!""""SeaFoam""""!!!!! &lt;--joke what is seafoam?
Old Apr 23, 2005 | 11:12 PM
v4lu3s's Avatar
RTFM
hammer and large pipe.
you should ahve looked at it before buying it. if you hold it up to light and can see light passng through its probably good enough to use.
Juice_boxx
Sep 20, 2005 08:59 AM
dayaftertomorrow
Apr 18, 2005 07:51 AM
dayaftertomorrow
Apr 13, 2005 06:35 PM
Superdragr45
Mar 8, 2004 09:36 AM
