Mahle Piston Pins Won't Fit!!!
Old Apr 17, 2005 | 08:05 PM
O RLY's Avatar
Default Mahle Piston Pins Won't Fit!!!
Okay I just received new Mahle Pistons for the H22A, I also bought Eagle H Beam rods, and yes, they are both for the H22A. Problem is this wrist pins won't go into the rods. They'll go into the pistons, but are just getting stuck on the rod when I go to put them through. Are they supposed to be snug. I'm not installing these myself, I'm just making sure I got the right parts. Are the pins supposed to be lubed in order to slide into the rod?
Old Apr 17, 2005 | 08:11 PM
PrecisionH23a's Avatar
Default Re: Mahle Piston Pins Won't Fit!!! (rfoster03)
Eagle rods require a little bit of force to slip the wrist pin in. Lube them up... and press them in.
Old Apr 18, 2005 | 05:20 AM
Daemione's Avatar
Default Re: Mahle Piston Pins Won't Fit!!! (PrecisionH23a)
Stick the rods in the oven, and the pins in the freezer . . . .
Old Apr 18, 2005 | 07:17 AM
O RLY's Avatar
Default Re: Mahle Piston Pins Won't Fit!!! (Daemione)
stick them in the oven...at what temp? how long. This actually works?
Old Apr 18, 2005 | 07:49 AM
98TypeSH's Avatar
yes but its going to be next to impossible to handle them without a clamp or something. (dont maul your pistons) The heat causes the metal to expand where the cold causes the metal to contract. In theory the hole in the rod should open just slighty enough to make it a little bit easier to put the pin in. When it cools, good luck gettin the pin back out.
Old Apr 18, 2005 | 09:37 AM
matix's Avatar
Default Re: Mahle Piston Pins Won't Fit!!! (98TypeSH)
Let us know how it goes. Are you running them with stock sleeves? Ive been waiting to see if these work fine with the frm cylinder walls.
Old Apr 18, 2005 | 09:41 AM
JDogg's Avatar
Default Re: Mahle Piston Pins Won't Fit!!! (matix)
did the rod fit in the piston?? also make sure to clay the thing. the set we tested fro mahle had the valve reliefs in the wrong place and bent all the exhaust valves. we had to take about 40thou off each side of the rod to fit it in the piston. we used a hone to make the pin fit. these things work great in the sleeves though.
but you will not find me buying anything mahle. we agreed to test their pistons on the conditions that we would get to keep the pistons and if anything was damaged they would fix it. well, 4 months later all we have to show for it is a set of bent ferrea valves and an h22 with no pistons.
mahle
Old Apr 18, 2005 | 10:07 AM
Default Re: Mahle Piston Pins Won't Fit!!! (JDogg)
earl had a similar problem when using manley rods
Old Apr 18, 2005 | 10:17 AM
JDogg's Avatar
even the stock rods wouldnt fit in the piston
Old Oct 5, 2009 | 06:05 PM
H-series's Avatar
all you got to do is just put a little push into the rod. i did it myself just a few days ago. easiler than i though.
Old Oct 5, 2009 | 06:06 PM
vinuneuro's Avatar
Welcome to honda-tech. This is a 4.5 year old thread, so don't expect a response.
DntFk_jdm
Engine Machining & Assembly
17
Mar 1, 2016 07:23 PM
CanadianEF9
Nov 8, 2010 04:16 PM
SiR99
Sep 1, 2006 09:17 PM
vwhracing
Apr 4, 2006 04:39 PM
boost fed ls
Jan 29, 2005 04:20 AM
