Code 22
Old Jan 30, 2002 | 11:23 AM
pelotudo's Avatar
Default Code 22
I hooked up my LED to my VTEC enguagement wire coming out of the VTEC selenoid last night. It lights up now when VTEC kicks in....woohoo.. Only downfall...I am now getting Code 22 from my ECU. I know this is the VTEC Pressure switch code, but is it hurting anything? The wire tapped (gator clipped) to the green/white wire coming from the selenoid is causing the problem. If I take it off, will it go away, or once the wire is violated....it has to be replaced? If I leave the wire on and reset the ECU, will it have any bad affects?
JB
Old Jan 30, 2002 | 01:09 PM
SiR Kid's Avatar
New User
Default Re: Code 22 (PeloTudo)
I can't beleive you VIOLATED the VTEC wire like that!
It probably just cut the wire or something.. I'd go ack in and remove the gator clip thing and see if that fixes it.. if it does, cut the wire, and solder the new light turn on wire in the middle... make it a perm connection, that shouldhelp.
Old Jan 30, 2002 | 03:02 PM
CRX-RX's Avatar
Default Re: Code 22 (SiR Kid)
So long as your getting the code, your not getting VTEC. What do you want, a light, or VTEC? And why are you asting your time on this, and not working on your O2 sensors?
Jdmkids Manny
Apr 26, 2016 11:06 PM
fishnfst
11
Nov 22, 2004 08:09 PM
R91Si
Oct 10, 2004 02:30 PM
pelotudo
Jan 30, 2002 11:43 AM
prjctCIVIC
Jul 7, 2001 09:50 PM
