Smoke from breather valves on valve cover.
Hey. I took my turbo d16 to the track on saturday. When I got back i noticed smoke comming from the breather valve on the valve cover. Can anybody help me out?
my prelude smoked excessivly on startup after 10 months of boost, turned out to be the ringlands... id suggest a compression or better yet a leak down test to be sure theres nothin wrong...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted lude »</TD></TR><TR><TD CLASS="quote">my prelude smoked excessivly on startup after 10 months of boost, turned out to be the ringlands... id suggest a compression or better yet a leak down test to be sure theres nothin wrong...</TD></TR></TABLE>
wurd
wurd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juiced2ndgenteg »</TD></TR><TR><TD CLASS="quote">it would have to be ALOT of smoke all the ime for it to be ringlands.</TD></TR></TABLE>
not if they're just starting to break up - I noticed some smoke, not alot (at first) when mine let go...
This is not always true. Mine smoked very little while not in boost. I also had pretty good compression numbers. But when I took the pistons out, the ringlands just fell apart like all the pics you see on HT of stock pistons.
Mine smokes a very small amount out of the breather. After it is warm it goes away. It might just be a little start-up blow by. Nothing to worry about. If you are really worried, do a leakdown.
-Ryan
-Ryan
lunareg
Aug 22, 2010 03:31 PM
