Wired for cruise control?
Old Apr 17, 2005 | 05:15 PM
Cuong-nutz's Avatar
Default Wired for cruise control?
Are civic prewired for cruise control?
Old Apr 17, 2005 | 05:31 PM
civictildeath's Avatar
Default Re: Wired for cruise control? (Cuong-nutz)
pull the driver side air vent out that is by the door. there will be a harness that has 14 points in it. not all may be wired when counting.
also there will be a hose of some sort or place for one on the rear lower drivers side of intake manifold
between the drivers side headlight and the strut tower there will be a 4 point harness
and then you need the buttons, actuator and i think thats it
Old Apr 17, 2005 | 05:51 PM
Cuong-nutz's Avatar
So are the EGs wired up for cruise control? I'm trying to install cruise control in my hatchback.
Old Apr 17, 2005 | 05:53 PM
Default Re: (Cuong-nutz)
you have to look for the harnesses i said to see. if they are there, then you need the switches and actuator. if they arent there, good luck
Old Apr 17, 2005 | 06:13 PM
Cuong-nutz's Avatar
Default Re: (civictildeath)
oh damn.. more wiring for me to do
Old Apr 17, 2005 | 06:15 PM
SOHC4life 96's Avatar
You also need the brain. I have one but it came out of my 96 ex. I'm sure it will work as long as the connectors are the same. And the throttle linkage.
Old Apr 17, 2005 | 06:19 PM
Cuong-nutz's Avatar
Default Re: (SOHC4life 96)
from the looks of it, i'm going to need a new pedal assembly as well... and do lots of wiring....
I'm pretty sure I got all the parts necessary covered... just need to get the wiring part down
I don't have the underhood harness:
Old Apr 17, 2005 | 06:29 PM
Deemeetree's Avatar
Electrician
Indeed.
You will need:
Pedal assembly # 2 and everything above it. From the looks of it...
Old Apr 17, 2005 | 06:35 PM
Deemeetree's Avatar
Electrician
Might help a litte:
http://www.sandmracing.com/m_e....html
Old Apr 17, 2005 | 08:49 PM
Cuong-nutz's Avatar
yeah, I bookmarked that awhile back. I never thought I'd would plan on doing such a conversion though I don't think anyone has done it before so I'm kinda on my own on this. Look out for a write up soon though
Old Apr 17, 2005 | 09:43 PM
Cuong-nutz's Avatar
Can anyone with a 92-93 CX/DX/VX model hatch look and see if they have the harness plug for the cruise control actuator that's next to the driver side strut tower?
Old Apr 17, 2005 | 09:50 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
I'm going to walk outside and see if my brother's car has it.
Old Apr 17, 2005 | 09:54 PM
Cuong-nutz's Avatar
haha sweet
Old Apr 17, 2005 | 10:06 PM
INVALID's Avatar
From working under my dash all day, I was relieved to see how much cleaner the wiring looked in a DX (less and more space). It was not prewired for cruise control. This was on a DX coupe. Sorry bro.
Old Apr 17, 2005 | 10:13 PM
Cuong-nutz's Avatar
holy poop... im in for some more backbreaking work...
thanks for looking
Jorsher's Avatar
Not sayin it's a bad idea, but why would you want to go through so much for cruise control? I will probably take mine out eventually. I rarely use it.
Old Apr 17, 2005 | 10:26 PM
INVALID's Avatar
Word of advice, in case you don't already do this, but take out your front seat. It's more comfortable, especially if you're going to be awhile.
Old Apr 18, 2005 | 06:54 AM
Cuong-nutz's Avatar
Default Re: (INVALID)
I was always lazy when it comes to taking the seat out... but that is a very good suggestion
joaco27
12
Sep 28, 2014 10:44 AM
JohannesPK
Oct 5, 2010 12:53 PM
Ficky
Honda Civic (2001 - 2005)
Nov 12, 2006 10:19 AM
Kesall
Jul 5, 2006 03:03 PM
dewoine
Oct 14, 2005 05:52 PM
