Quick knock sensor question
broke mine taking the plug off. my engine is a JDM b16 2nd gen.
question is what knock sensors can u use to replace it? will any B series sensor work?
help asap please
help asap please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">ah HA lol that would explain a lot then
so would a knock sensor out of a d16y8 fit then?</TD></TR></TABLE>
Yes (if it has one) and so will a GM unit with 1/8NPT threads. Just dont go back to BSPT.
so would a knock sensor out of a d16y8 fit then?</TD></TR></TABLE>Yes (if it has one) and so will a GM unit with 1/8NPT threads. Just dont go back to BSPT.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
Yes (if it has one) and so will a GM unit with 1/8NPT threads. Just dont go back to BSPT.</TD></TR></TABLE>
dont understand ur abreviations, what is BSPT? how much is a GM unit?
thanks<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr aka onefstek »</TD></TR><TR><TD CLASS="quote">any honda knock sensor will work. B , D , H or whatever series.</TD></TR></TABLE>
1 more question i forgot to ask about that last night was do they all have the same plugs for the wiring harness? or would say an H series KS have a different plug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">bump for an answer, are all the plugs that plug into the knock sensor the same for each harness, H or B series?
As far as I know all the Honda knock sensors have the same plugs.
Its only one wire so its not a big deal. The GM sensor does not have a clip at all. Its got like a screw tight fitting
You can see the gray plug in this pic.
</TD></TR></TABLE>As far as I know all the Honda knock sensors have the same plugs.
JDM_EK_JOE
May 2, 2006 07:55 PM
