which oil filter sandwich should i get 4 oil pressure switch?
hello sirs....
i want to buy a oil filter sandwich to place the oil pressure switch. which one sould i get?
best regards moshik galimidi
p.s
am i gonna need any fittings to install the oil pressure sensor on the sandwich? is it the same tread ?
p.s
I'm using a Greddy sandwich plate, which has 1/8 BSPT ports. The GE has 1/8 NPT ports. I believe Flamenco-T told me that you can screw in a NPT male into a BSPT female and not worry about leaking. So keep that in mind if you get a Greddy sandwich plate.
I plan on screwing a 1/8 Tee into my Greddy plate and running the oil feed off of on end. Then I was just gonna take my Autometer oil pressure sender and screw it into the other end of the Tee. Either that or mount the Autometer sender on the firewall and run a -3 AN line from the Tee to the sender on the firewall. The reason I'm using a Tee is cause one came with my Revhard kit and it was meant to be used in my stock oil pressure sender BSP port. But since I'm using a sandwich plate I thought I'd use it for that instead.
accordfreak
Jan 27, 2004 12:52 PM
