I need to change coolant in my 2000 civic How much coolant it will take?
Old Apr 17, 2005 | 09:06 AM
Jaydeep's Avatar
Default I need to change coolant in my 2000 civic How much coolant it will take?
I need to change coolant in my 2000 civic How much coolant it will take? How much water should add?
Old Apr 17, 2005 | 09:16 AM
SOHCmaster's Avatar
buy one of those testers and follow directions, its pretty simple.
Old Apr 17, 2005 | 09:31 AM
Luserkid's Avatar
Default Re: (PK SPEED)
Get a 50/50 mix gallon bottle from Autozone, drain and fill until you cant fill no more.
You know how to do it correctly right? With the motor on and let it burp a couple times. Then bleed the system.
Old Apr 17, 2005 | 09:36 AM
ExiledinIN's Avatar
Default Re: I need to change coolant in my 2000 civic How much coolant it will take? (Jaydeep)
If you buy the coolant from Honda, it is pre-mixed.
Old Apr 17, 2005 | 09:50 AM
Jaydeep's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Get a 50/50 mix gallon bottle from Autozone, drain and fill until you cant fill no more.
You know how to do it correctly right? With the motor on and let it burp a couple times. Then bleed the system. </TD></TR></TABLE>
Can you explain more how to do this. SO I have to turn on motor and then put coolant and water.
msmithgsr2131
Feb 19, 2006 08:39 PM
tianporn
Feb 17, 2005 11:03 PM
MikeyDB7
Jan 21, 2004 11:04 PM
benmasters
May 25, 2003 12:47 PM
glock
10
Aug 8, 2002 06:21 AM
