Just bought girlfriend a 92 integra and this is what i noticed today.....any thoughts?
Old Apr 17, 2005 | 08:59 AM
DAguyLS's Avatar
Default Just bought girlfriend a 92 integra and this is what i noticed today.....any thoughts?
Car: 92 Integra LS
Miles: 160,000
Trans: Auto
It wasn't happening yesterday, but today she started the car (it has 160,000 miles by the way(but runs good and shifts pretty smooth)) and saw the exhaust was shaking a little bit. So i popped the hood and first thought maybe a mount was loose or worn. And then proceeded to feel around and felt the plugs and the first plug from the right I felt almost a tapping when the motor was on. <<<this is what i was wondering about. I felt the other 3 and noticed nothing. So what could this be?
Thanks ahead of time
SlamdLScivic
Old Apr 17, 2005 | 09:02 AM
DAguyLS's Avatar
I haven't changed anything on it yet. So maybe the plugs are old or wires, i'm not sure. Any positive input is apprietiated.
Old Apr 17, 2005 | 09:09 AM
DAguyLS's Avatar
and also sometimes it doesn't start up on the first try. Fuel pump?
please give me some words of advice.
Old Apr 17, 2005 | 09:14 AM
adaml2nv's Avatar
Default Re: (slamdLScivic)
i'd say just do a tune up on it and work on from there
Old Apr 17, 2005 | 09:17 AM
DAguyLS's Avatar
anyone else have an idea of why I feel a slight tap on the first plug on the right?
and thanks for the input adaml2nv
Old Apr 17, 2005 | 09:21 AM
Rpizzle's Avatar
yea dude you needed your 90,000 mile tune up done like, 70,000 miles ago, get that tune up done timing belt etc they do the plugs and all, that is what you need
Old Apr 17, 2005 | 09:23 AM
DAguyLS's Avatar
much thanks bro. I knew it needed one, we just bought it yesterday, so i'm in the process of updating some much needed repairs.
Thanks again
Old Apr 17, 2005 | 10:11 AM
DAguyLS's Avatar
so has anyone touched the top of a plug and felt a tap from below? it's not when i touch the valve cover anywhere around the plug, just on the top of the plug itself.
Old Apr 17, 2005 | 11:02 AM
DAguyLS's Avatar
anyone?
Old Apr 17, 2005 | 12:34 PM
RidinStock's Avatar
I've never felt that before, but as for the exhaust shaking around, I think you should just check the hangers. My exhaust used to shake and rattle against the LCA and make all sorts of ugly noises when it was cold. Bump for more info on your spark plug question!
Old Apr 17, 2005 | 02:59 PM
Irish Integra's Avatar
Default Re: (RidinStock)
Take out the plug and inspect it, see if the piston is slapping it; could be an incorrect plug or maybe it's just loose and the compression is causing a shake.
Either way, change the belt and give the car a good service, oil&filter, air filter, plugs adjust the tappets (valve to rocker clearances) and check the ign timing. You might need a new rocker cove gasket when you take it off. GL
Old Apr 17, 2005 | 03:04 PM
DoctorGSR's Avatar
not sure about the plug, but as far as it not starting, change the main relay. they are notorious for going bad on older hondas. get a new one and it'll start right up no problem.
Old Apr 17, 2005 | 03:48 PM
DAguyLS's Avatar
Word up guys, thanks
Here's what i did today:
1. New Plugs
2. New Wires
3. New T-stat (was stuck open)
4. Oil/Filter Change
5. Headlight adjustment (they pointed 2 feet infront of the car lol)
6. New Air filter
First things first....the tapping coming from the plug was due to a loosely tightened plug.
Second...it must of been also causing the motor to vibrate a bit cause the exhause stopped shaking after i did plugs and wires.
But i still have one question....whenever i changed the wires i noticed that the one that was loosely tightened was filthy. Anyone know why that would be? And the other 3 were perfectly clean. Also the plug below that wire was nasty too, but the rest were much cleaner.
Anyone know why it would be dirty when the others weren't?
Thanks to everyone for the help
and quikLS i'll look into the main relay...thanks
Old Apr 17, 2005 | 04:36 PM
fergy016's Avatar
might not of had a clean seal on the top of the cylinder that the plug goes into. The valve cover donut seal I mean. then a little bit of oil got in there?
Old Apr 17, 2005 | 04:45 PM
DAguyLS's Avatar
thanks fergy
Old Apr 23, 2005 | 08:42 AM
With the plug being loose, it was probably missing a bit, that'd leave the plug fouled up after a while. As far as the top part goes, possibly there was some compression leakage past the threads since it was loose, that'd cause it to be pretty dirty over time. Keep an eye on the new plug in there. Make sure you replace the T-belt if you don't know the history of the car.
Old Apr 23, 2005 | 02:13 PM
DAguyLS's Avatar
thanks for the reply. i've been keeping an eye on that plug and it's clean so far. and i changed the belt already with the tune up. but thanks again
TTatro
Mar 28, 2019 03:40 PM
Randy Phillips
Engine Management and Tuning
Jul 27, 2017 02:28 PM
92gsrdb2
Sep 30, 2013 10:59 AM
hatch4raceb16
Mar 7, 2004 07:18 PM
