92 DB2 Problems
Old Aug 5, 2012 | 10:03 AM
92gsrdb2's Avatar
Default 92 DB2 Problems
New member here but I have recently been stumped by my Integra which is a 92 Integra GSR with the Originial B17a1 and the YS1
Background Info
92 Integra Gsr
Rebuilt B17a1
Boosted and Tuned on Neptune
Wire Tuck / Custom Engine bay
p61 ecu
After being boosted and tuned for about 4 days I began having trouble with my main relay so I had the joints resoldered. Everything worked fine for about a day until I was driving home from work coasting down a hill when the car began to sputter extremely bad and eventually stalled because of it. So I coasted to the side of the road and let the car sit for a few minutes before trying to restart it and it would crank but not start. So I had someone run and get me a new Main Relay because I thought that was the problem. The car fired right up and made it almost home till it started sputtering out again. So I tried a new distrubutor that I know is working and put new plugs in it NGK 4544. After that we did some testing and we are getting fuel to the fuel filter and power to the distubutor but no spark off the spark plug. I pulled the engine harness off to make sure there were no bare wires or anything cut everything seems to be fine also tried another ecu. Im stumped if anyone has any suggestions on things to try or if theyve had similar problems I would greatly appreciate the help.
Thanks!
Old Aug 5, 2012 | 11:20 AM
92gsrdb2's Avatar
Default Re: 92 DB2 Problems
oh forgot to add that the timing belt is fine and the timing is dead on.
Old Sep 30, 2013 | 10:54 AM
smit7277's Avatar
Did you ever find out what was wrong?
Old Sep 30, 2013 | 10:59 AM
KILLAB17VTEC's Avatar
Genetically Gay
Check your timing!
DeltaAlpha9
Aug 4, 2017 05:20 PM
20mph
May 22, 2015 06:56 AM
hawjboiz08
Aug 1, 2012 05:55 AM
1503ef9
Jun 19, 2009 04:13 PM
