Blue box with upgraded fuel----->10psi okay?
I've got the walbro fuel pump and 310's with an aem fpr, i want to boost around 10psi (have upgraded bottom end) will the blue box and my fuel system be okay at that amount of boost? what about my part throttle driving. thanx guys! (yes i know how much you guys like to say just get uber or hondata, I WILL, just not right now!)
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I'd run the blue box on a stock motor, not a built one.
If you spent the money on a built block, at least treat it right with proper fuel management.
What kind of motor do you have, what mods? I wouldnt run 10 lbs on a blue box period but it has been done. I would just keep it to 8 lbs for now if you insist on the blue box for now. Like boostincoupe said i would run it on a stock motor but not a built one
Im running 8-10 psi for the last 2 years+ on the blue box on a y8, stock internals.. My wide band is telling me Im at 11.5 @ WOT w/blue box and 14.6 at idle, stock injectors too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PK SPEED »</TD></TR><TR><TD CLASS="quote">Im running 8-10 psi for the last 2 years+ on the blue box on a y8, stock internals.. My wide band is telling me Im at 11.5 @ WOT w/blue box and 14.6 at idle, stock injectors too...</TD></TR></TABLE>
Dope!
Are you running a Walbro fuel pump?
Did you retard your timing at the distributor at all?
Dope!
i ran a 13.1 (spinning like a mo fo 1-3rd, with small slics) with a greddy blue box at 10lbs of boost on a b16a2 with srp's and eagle rods and 310 injectors.
**sorry, no real apparent reason for this post other then to make him feel a lil safer about the blue box.
