turns over but no spark
The engine will turn over but there is no spark from any of the plugs. i started it a couple of days ago and it sounded like it was running on one cylinder, it ran for a few seconds and died. now it just turns over.
the ignitor in te distributor might ave gone bad..or it could simply be a fuse in the fusebox in the engine bay..trust me i've been there..pulled up distributor n the whole works..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littlegreend15 »</TD></TR><TR><TD CLASS="quote">how do you check the ignitor?</TD></TR></TABLE>
Easiest way is to swap it out with known good unit. I think I would lean more towards the coil however.
the coil is fine, i ran through all the checks and what not, it checks out, where can you get an ignitor? do autoparts stores sell them, or its it a dealer item, and is the one out of my d15 distributor the same? cuz i know that one worked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littlegreend15 »</TD></TR><TR><TD CLASS="quote">the coil is fine, i ran through all the checks and what not, it checks out, where can you get an ignitor? do autoparts stores sell them, or its it a dealer item, and is the one out of my d15 distributor the same? cuz i know that one worked</TD></TR></TABLE>
You COULD get it at the dealer, just don't expect it to be cheap. Kragen has them, but same story.
had the same problem a about 2 months ago and it was in fact my ignitor a buddy from work gave me one he had and it started up sounded like **** for a little bit while it blew all the **** out the tail pipe from being flooded because i had other problems. but im guessing it is your ignitor
edit** oh yeah and check you're mine were gone pretty much after all the work
Modified by 99TurboFerio at 11:41 AM 4/17/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Littlegreend15 »</TD></TR><TR><TD CLASS="quote">ok so what about the ignitor in my d15 distrbutor?</TD></TR></TABLE>
Should work fine. Go try it.
check the ignitor...for some reason my gsr blew 2 of them! and yes u can use the d15 ignitor...i believe they all work the same...i think all u have to do is change the braket!
i swapped in my d15 ignitor, nothin, THEN i swapped coils, and it RAN!!!!!! oh my god i'm so happy and relived i've been so stressed about this for the past week, i checked the coil exactly like the hanes manual said and it was fine, moral of todays story, the haynes manual is useless, but i dont care, my car started!!!!
shorty0o29
12
Sep 27, 2004 05:01 AM
itsmike
Jul 25, 2004 06:59 PM
