IACV Idle Air Control Valve Humming?!
Old Apr 16, 2005 | 07:51 PM
dunkd's Avatar
Default IACV Idle Air Control Valve Humming?!
when the iacv valve is plugged into the harness it makes a faint humming sound and sometimes will get louder... When I unplug the clip from the IACV it stops... ANY IDEAS?! its not something i can just ignore...
it does it when I just turn the key to "ON" and not starting the motor, might do it when the car is running too not sure tho bc ive only ran it for about 3 minutes so far...
95 GSR iacv on JG edelbrock intake manifold
Old Apr 17, 2005 | 03:02 AM
SkRiBLaH's Avatar
Default Re: IACV Idle Air Control Valve Humming?! (dunkd)
normal.
Old Apr 17, 2005 | 08:20 AM
dunkd's Avatar
uhhh, i dont think so.
Old May 9, 2005 | 10:11 PM
mooook's Avatar
Default Re: (dunkd)
i just put a GSR motor in my EJ8 and i have the same thing happening with only difference is i have a Skunk2 manifold.
Old May 22, 2005 | 11:54 PM
crucian's Avatar
Default Re: (mooook)
Mine is humming too. I took my IACV off to see if it was moving while I discoonect and reconnected the plug and it was not. Normally when a solenoid humms like that, something is stopping it from working or it is bad.
Old Feb 8, 2006 | 07:51 AM
91-lsvtecsi's Avatar
Default Re: (crucian)
bump same thing is happening here any clue to why this is happing
THCivic29170
Jun 14, 2009 10:46 PM
SupraRXZ
Jan 23, 2006 04:31 PM
Chrislow
Apr 26, 2004 09:55 AM
2000Accord5sp
Dec 18, 2003 06:57 PM
PhilJ95GSR
May 6, 2002 08:47 PM
