IACV Idle Air Control Valve Humming?!
when the iacv valve is plugged into the harness it makes a faint humming sound and sometimes will get louder... When I unplug the clip from the IACV it stops... ANY IDEAS?! its not something i can just ignore...
it does it when I just turn the key to "ON" and not starting the motor, might do it when the car is running too not sure tho bc ive only ran it for about 3 minutes so far... 95 GSR iacv on JG edelbrock intake manifold |
Re: IACV Idle Air Control Valve Humming?! (dunkd)
normal.
uhhh, i dont think so.
Re: (dunkd)
i just put a GSR motor in my EJ8 and i have the same thing happening with only difference is i have a Skunk2 manifold.
Re: (mooook)
Mine is humming too. I took my IACV off to see if it was moving while I discoonect and reconnected the plug and it was not. Normally when a solenoid humms like that, something is stopping it from working or it is bad.
Re: (crucian)
bump same thing is happening here any clue to why this is happing
