Rear Subframe bolt strength?
Old Apr 16, 2005 | 06:02 PM
snatch's Avatar
Default Rear Subframe bolt strength?
I snapped the bolt in the middle of the car on what I think is where the subframe is. It's where you would install a lower tie bar. Too late for the dealer. Will a Home Depot bolt hold up until early this week?
Old Apr 16, 2005 | 06:08 PM
Lord Helmet's Avatar
Default Re: Rear Subframe bolt strength? (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">I snapped the bolt in the middle of the car on what I think is where the subframe is. It's where you would install a lower tie bar. Too late for the dealer. Will a Home Depot bolt hold up until early this week?</TD></TR></TABLE>
It better be a Grade 10 or higher bolt. That bolt is a very tough bolt that supports a lot of twist and turn coming out of the trailing arms.
Old Apr 16, 2005 | 06:11 PM
Kyles ej1's Avatar
Default Re: Rear Subframe bolt strength? (sleeperciv)
man when i installed my tie bar i used a OSH grade 8 bolt and no problems here
Old Apr 16, 2005 | 06:31 PM
snatch's Avatar
Default Re: Rear Subframe bolt strength? (ineedaswap)
Well it says 8.8 on the head, but that translates I believe to a SAE Grade 5 bolt. So looks like I should try and not drive it as much as possible eh?
Although I've heard of people using them without any problems whatsoever for months or years.
Old Apr 16, 2005 | 09:25 PM
egtwincam's Avatar
that bolt may snap upon a hard impact, like a pot hole,accident,etc. i would order one from the dealer when you get a chance.
Chiller
Jan 6, 2005 06:55 AM
Thrillhouse
Sep 19, 2003 09:04 AM
Matt B
Apr 20, 2003 07:12 PM
rasta420
Jul 24, 2002 12:32 PM
b18bvudoo
Aug 16, 2001 08:14 AM
