anyone running a msd sci or something similar?
Old Apr 16, 2005 | 01:56 PM
budget's Avatar
Default anyone running a msd sci or something similar?
thinking about running it on a turbo set up of mine. what it be worth it w/o an upgraded coil?
Old Apr 16, 2005 | 04:18 PM
Firedrake's Avatar
Default Re: anyone running a msd sci or something similar? (ratboy)
Why the hell would you run an aftermarket ignition without a $30 aftermarket coil? The coil is the weaker part of the ignition than the actual ignition, stock honda ignitions with a good 50Kvolt coil can make 500+ whp. Yes, it will still be worth it, but get the damn coil. You'll also notice better mileage because of more efficient combustion, Jesse (goes by Pirate McFred) on here has my SCI on his car right now and said he's getting a couple more mpg......I had my plugs gapped at .28 on my turbo setup, and with a 6AL and a Blaster SS coil I had absolutely no ignition problems (blowing out spark, etc)
Brian
Old Apr 16, 2005 | 04:32 PM
budget's Avatar
what about just the coil alone
Old Apr 16, 2005 | 04:36 PM
clemsoncb7's Avatar
Default Re: anyone running a msd sci or something similar? (Firedrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firedrake &raquo;</TD></TR><TR><TD CLASS="quote">Why the hell would you run an aftermarket ignition without a $30 aftermarket coil? The coil is the weaker part of the ignition than the actual ignition, stock honda ignitions with a good 50Kvolt coil can make 500+ whp. Yes, it will still be worth it, but get the damn coil. You'll also notice better mileage because of more efficient combustion, Jesse (goes by Pirate McFred) on here has my SCI on his car right now and said he's getting a couple more mpg......I had my plugs gapped at .28 on my turbo setup, and with a 6AL and a Blaster SS coil I had absolutely no ignition problems (blowing out spark, etc)
Brian</TD></TR></TABLE>
I second that, since the coil is so inexpensive anyways, I say go with it!
Old Apr 16, 2005 | 07:42 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ratboy &raquo;</TD></TR><TR><TD CLASS="quote">
thinking about running it on a turbo set up of mine. what it be worth it w/o an upgraded coil?</TD></TR></TABLE>
If you want to run turbo set up with MSD, then MSD 6BTM is an ideal for engines with turbo or supercharger.
Old Apr 16, 2005 | 10:18 PM
Firedrake's Avatar
Default Re: anyone running a msd sci or something similar? (xbn83)
All the BTM does is pull timing based on boost, and if you have half a brain and are building a boosted car you've already got proper engine management that has tuned timing maps and doesn't need boost-dependent timing pull
Old Apr 17, 2005 | 09:11 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xbn83 &raquo;</TD></TR><TR><TD CLASS="quote">If you want to run turbo set up with MSD, then MSD 6BTM is an ideal for engines with turbo or supercharger.</TD></TR></TABLE>
msd6btm is not worth the money i find
Old Apr 17, 2005 | 09:17 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: anyone running a msd sci or something similar? (PrettyLude)
any one have any luck with the jacobs ?
jsnm
Nov 10, 2005 10:39 AM
mrod006
Aug 1, 2004 09:48 PM
4inspeed
Feb 9, 2004 01:13 AM
NyQuiL
Sep 12, 2003 08:57 AM
