Msd sci + ss blaster coil good for my setup?
Old Sep 11, 2003 | 10:27 AM
NyQuiL's Avatar
Default Msd sci + ss blaster coil good for my setup?
Ive searched on this before and gotten 2 results on decently high hp cars running ignition setups.
Ive seen posts of where people say the stock ignition can handle up to some crazy hp then ive seen posts where people were maxing out spark after 400+ whp.
Im shooting for 400+ whp so would a msd sci + the ss blaster coil be alright for me?
Old Sep 11, 2003 | 10:30 AM
xvietxkhmerxboix's Avatar
Default Re: Msd sci + ss blaster coil good for my setup? (NyQuiL)
Old Sep 11, 2003 | 11:22 AM
NyQuiL's Avatar
blamp?
Old Sep 11, 2003 | 11:23 AM
stackz's Avatar
at the jetties fishin'
Community Builder
I run one and like the way it helped to smooth the idle out and allows me to run a wider spark gap than stock....burn that fuel baby
Old Sep 11, 2003 | 11:35 AM
boostaholic's Avatar
Default Re: Msd sci + ss blaster coil good for my setup? (stackz)
I'd go with a Digital 6 and HVC coil for 400+.
Old Sep 11, 2003 | 01:21 PM
NyQuiL's Avatar
Default Re: Msd sci + ss blaster coil good for my setup? (boostaholic)
any other opinions?
Old Sep 11, 2003 | 02:33 PM
Blown90hatcH's Avatar
Its a tough call. I made 464 with stock honda distributor and a MSD blaster ss coil. I made 464 with the digital 6 ignition and the HVC coil. I very little gain with the digital 6 and HVC. I saw some gain in my wallet from going to the blaster ss coil.
Old Sep 11, 2003 | 02:56 PM
Marauder's Avatar
Default Re: Msd sci + ss blaster coil good for my setup? (Blown90hatcH)
I enjoyed my SCI+ Digital and Blaster SS coil. I disconnected it sinceI was having ignition troubles and just trouble shooting it. Now that I'm running stock ignition, the only difference I have noticed at my power level is that idle was much better and smoother low rpms with the MSD ignition. Not much of a difference at the top end. Just run some good plugs. I'm probably going to hook up the MSD ignition again in the near future.
Old Sep 12, 2003 | 08:07 AM
NyQuiL's Avatar
Default Re: Msd sci + ss blaster coil good for my setup? (Marauder)
this is probably a dumb question but, do i have to run a resistor box for injectors? if i have an msd box and ss blaster?
Old Sep 12, 2003 | 08:35 AM
Marauder's Avatar
Umm...nope! That's only if you install low resistance fuel injectors. The Honda ECU needs to use 10-13 ohm injectors, so if you use injectors with like 4 ohm resistance, then you need a resistor box.
Old Sep 12, 2003 | 08:57 AM
Andrea's Avatar
Stock is good between 400-500whp. An aftermarket coil would be a good idea to give faster charge times between firing.
jdm inc
Apr 5, 2009 09:32 AM
jsnm
Nov 10, 2005 10:39 AM
budget
Apr 17, 2005 09:17 PM
mrod006
Aug 1, 2004 09:48 PM
