A/C leaks water inside car - help!
Old Apr 16, 2005 | 12:16 PM
aklbear's Avatar
Default A/C leaks water inside car - help!
I have a 5th gen Accord, and when the air conditioning is run, water drips (in great quantities) from the dash above the passenger footwell. I assume a drain is blocked, but this is my first experience with an A/C system.
Is this something that I can fix, or does it need to be looked at by a specialist?
I checked the factory workshop manual, but did not find any information that seemed helpful.
Old Apr 16, 2005 | 04:31 PM
drdisco69's Avatar
Default Re: A/C leaks water inside car - help! (aklbear)
You can start by taking off the hose that drains the AC evaporator and seeing if there's any trash in there you can clear out. If there's a whole lot, you may have to take the evaporator box apart, not an easy task, something you may want to give to someone else. You'll have to evac the AC system if you want to take it apart, so that alone is a problem.
Old Apr 16, 2005 | 09:45 PM
Honda Crx's Avatar
could mean the ac is going bad
Old Apr 17, 2005 | 08:17 AM
Runnerdown's Avatar
Take a blow gun and give the a/c drain under the car a shot. That fixes it 99% of the time.
Old Apr 21, 2005 | 11:40 PM
aklbear's Avatar
Default Re: (Runnerdown)
Thanks very much for the info, guys...that's exactly what I was looking for. I don't have a compressor, but at least I know exactly WHAT to ask for if I call around to some shops (i.e. "I need to have my A/C drain blown out...")
Old Apr 22, 2005 | 07:33 AM
Ev_eezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Take a blow gun and give the a/c drain under the car a shot. That fixes it 99% of the time.</TD></TR></TABLE>
Confirmed. If the problem reoccurs within a month, then you may have a problem...
metalmole
Honda Civic (2001 - 2005)
Jun 18, 2014 10:30 PM
DACteg
Jul 27, 2010 11:04 AM
adrenalinesaint
Aug 30, 2007 11:23 AM
Phink
Jun 24, 2007 07:31 PM
Double_Dk
Jun 30, 2004 08:34 PM
