Water leaking into car when AC is on... HELP!
Hey all. I just got my AC refilled. Now, when I am sitting in my "Cool" car, water will start dripping and sometimes pour out are the passenger side and at the middle of the car near my gas pedal. What could be causing this? Anyone????
Re: Water leaking into car when AC is on... HELP! (Double_Dk)
is it alot, or is it just little drops, cuz that was happenin to me when i got my ac fixed, and it went away after a lil while
Re: Water leaking into car when AC is on... HELP! (tallblondkid)
There's a drain hose that runs from the HVAC unit through the firewall. Sometimes it cloggs and leaks water into the car. If yo get down on the passenger side you should be able to see it.You can use some compressed air to clear it out.
Well, sometimes it just drips every now and then, but other times, it's like a solid stream for a few secs. Good enough to get your foot wet.
What do you guys think
either the hose mentioned above it clogged, or is disconnected. AC evaporators remove moisture from the air, that is the water dripping. Clean the tube and make sure it is connected.
DACteg
07-27-2010 11:04 AM
adrenalinesaint
08-30-2007 11:23 AM
gtowni3
10-05-2004 06:19 PM
