Tranny Level Help!
Old Apr 16, 2005 | 12:05 PM
Bond's Avatar
Default Tranny Level Help!
Well today I decided to check my tranny level. I left it in the garage floor (which is perfectly flat) and took off the filler plug. It then took a massive dump all over the floor. Tranny fluid was just pouring out! I have never seen so much tranny fluid come out before. So I quickly checked my helms to see if I did it right. They suggest that you even jack it up making moore fluid drain towards the filler hole and pour out so I decided to not do that and check it out with you guys and get your opinions. Should I jack it up and romove the filler bolt and let more out. I have no clue what Honda was thinking when they did all the work on it before I bought it from them. So what should I do? Just stop and tighten it back up or jack it up and drain more?
Also ever since I bought the car it has always had this "clunk" or jerk when I let off the gas around 2-3000rpm to shift. Could this have been from the overfilled tranny?
Old Apr 16, 2005 | 12:31 PM
Bond's Avatar
Default Re: Tranny Level Help! (Bond)
Bump.
Old Apr 16, 2005 | 12:33 PM
97dxnut's Avatar
it sounds like you actually took out the drain plug, I would just let the entire tranny drain and then fill it back up to spec
Old Apr 16, 2005 | 12:58 PM
Bond's Avatar
Default Re: Tranny Level Help! (97dxnut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dxnut &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like you actually took out the drain plug, I would just let the entire tranny drain and then fill it back up to spec</TD></TR></TABLE>
No trust me I know the difference. The drain plug you don't need a socket for. Also the filler hole is not at the bottom of the tranny, it's about half way up. Trust me I know which is which.
Old Apr 16, 2005 | 02:29 PM
Bond's Avatar
Bump. I just took it on a spin and it completely stopped doing that clunking and jerk in 1st and 2nd. I am so happy that it's gone. It was really pissing me off. Can a overfilled tranny really cause it to go all crazy like that? Also can somebody help me out with another problem. The car jerks/puleses when I let off the gas. It usually happens in 1st and 2nd around 2000rpm. Like it will happen in a parking lot and when going slow (school zones, etc.). I need some help so please leave some reply's.
faster Type R
Honda Civic (2006 - 2015)
Nov 11, 2009 04:12 AM
Adrian G. Aka JDMonkey
Oct 18, 2006 04:17 PM
.one lane
May 2, 2006 05:38 AM
DA jeshy
Mar 7, 2006 01:31 PM
B2FiNiTY
Oct 30, 2002 05:50 AM
