Look at my sparkplugs....
Old Apr 16, 2005 | 11:49 AM
Maxime's Avatar
Default Look at my sparkplugs....
I hope we-todd-did-racing allow hosting on this website.
Anyways, It's spring so after changing the defective o2 sensor (which cause the car to run extremely rich) last week. I did an oil change and changed the sparkplugs this week. I know the sparkplugs doesnt look good. It's because the car ran very rich for several weeks. That's why I'm changing them. But what surprise me is the sparkplug of the 2nd cylinder is not the same color as the other. It's very white. Is the injector defective?
Old Apr 16, 2005 | 11:55 AM
egtype-r's Avatar
Default Re: Look at my sparkplugs.... (Maxime)
bump would also like to know
Old Apr 16, 2005 | 04:15 PM
Maxime's Avatar
ttt
Old Apr 16, 2005 | 04:31 PM
evosol's Avatar
Default Re: (Maxime)
I dunno what kind of injectors you're running but it could be possible ones clogged?
Old Apr 16, 2005 | 04:32 PM
mrbsponge's Avatar
i never get too overly concerened with the color of the ceramic, you need a flashlight to look down into the spark plug, all the way at the bottom you will see a slight "ring" this is where you read the plugs from.
they dont look bad or anything and if you arent use to reading plugs alot i could see your concern from the one being almost new looking on the ceramic
Old Apr 16, 2005 | 05:12 PM
s2kdre's Avatar
Default Re: (mrbsponge)
it should be fine, theres carbon build up on the threads. I dont think its too lean
Old Apr 16, 2005 | 06:15 PM
ITR981002's Avatar
Looks fine to me, sometimes one or 2 can look different from the others, don't worry too much about it.
Old Apr 17, 2005 | 03:10 AM
Maxime's Avatar
Default Re: Look at my sparkplugs.... (ITR981002)
Thanks guys. I'll run the new plugs for a few days then I take a look at them to see what they look like.
Old Apr 17, 2005 | 08:10 AM
mrDFWmechanic's Avatar
your running lean thats why the plugs are white
Old Apr 17, 2005 | 09:10 AM
SOHCmaster's Avatar
I would run one more test with new plugs, and dont add any fuel additive or octaine stuff and make sure the gaps are all good. Drive it for a week and pull em and check em out again.
Old Apr 17, 2005 | 09:30 AM
Phase Change Racing's Avatar
Default Re: (PK SPEED)
Trying to "read" sparkplugs that have any more use than 1 pass on them is pretty much a waste of time. The hydrocarbon ring (mentioned above) is going to be an innacurate measure since it is WOT A/F we are concerned with. The color of the ceramic is just a bad measure to go by. The ceramic being glossy or speckeled, however, would be something to consider. The other biggie is the "blueing line" on the ground strap which is another measure that really isn't any good after 1 pass since it is a measure of maximum cylinder temp/pressure.
Throw a fresh set of plugs in, make a WOT pass, yank em, and check em. Let us know how they look.
Buffalo
Jul 9, 2007 06:27 AM
h kid
Sep 9, 2005 03:09 PM
handa
21
Apr 2, 2005 11:43 PM
c61lude
Mar 11, 2005 10:03 PM
TurboBumblBee
May 25, 2004 10:15 AM
