HELP !! 94 accord lx replace the stock exhaust system HELP !!
hi, everyone new to this forum. I bought a rear part of the exhaust ( the back pipe and the muffler). I saw 2 bolts between the stock pipe connected with the mid pipe. I should loosen it in order to install the new one, right? However, that waw so tight, and I don't want to force it.
Does anyone has changed their 94 accord rear exhaust by themselves? Can provide me installation instruction, have picure will be great. Thanks x 1000.
Go pick up some liquid wrench and soak the bolts and let them sit for a while then try they should come loose a lot easier. If not try it again and try tapping the bolts and let them sit a little longer. It's works trust me I had to do it with my exhaust a few weeks ago and it was the same situation.
sometimes it takes a good ol breaker bar, if you get enough leverage theyll come out pretty easy.... but if you have low clearance, try to get it torched a bit if you have one then go at it... or leave the car on for a bit to try to heat up the bolts for a few...
Jacking up the car can help you get more leverage. You'll need some form a breaker bar to break them loose. If you know anyone that has access to air tools, that would solve your problem...
Prophecy0
Feb 18, 2007 12:24 PM
95GS-Racin
Jun 12, 2003 10:52 AM
GSRaCeRbOI
Jul 24, 2002 10:07 AM
