help with 5spd h22 into 95 accord lx auto!!
Old Apr 16, 2005 | 09:24 AM
JBk24crx's Avatar
Default help with 5spd h22 into 95 accord lx auto!!
I want to swap a 5spd m/t h22 into my 95accord auto lx.what do I need to make this swap possible, from mounts to axles etc.all your help will be gratefull.
Old Apr 16, 2005 | 09:36 AM
TypeRKoncepts's Avatar
Search is your friend but the swap is fairly str8 forward. You can use either the accord axles or prelude (prelude recommended) make sure you use the halfshaft for whichever axle u wanna use. Use the accord mounts just need a little shaving on drivers side.
tranny mount will need to be removed as well as bracket, weld in the 5spd accord bracket and use the 5spd accord mount
I had problems with my clutch pedal not being a bolt on affair, i wasn't sure of the exact trim and year of the accord it came from so that might have been the issue, needed a custom bracket. And i bought all the accord 5 spd parts- **** linkage, shifter, misc lines, slave and master cylinder etc.
Old Apr 16, 2005 | 10:09 AM
JBk24crx's Avatar
Default Re: (TypeRKoncepts)
thanks for the great info anyone else.
Old Apr 16, 2005 | 01:35 PM
95accordh22a's Avatar
Default Re: (JBLSVTEC)
i used the prelude drivers side mount it was alot easier and for the tranny mount bracket no welding was required.
hindelk
Mar 9, 2012 10:14 AM
dutchman5
Dec 18, 2005 12:13 AM
sinister2c
Jun 22, 2005 11:59 AM
Civichatch2k
Aug 9, 2003 04:55 PM
HarryB
May 23, 2003 04:43 PM
