door lock automatically locks itself when I shut my door!! HELP
Old Apr 16, 2005 | 08:42 AM
Rpizzle's Avatar
Default door lock automatically locks itself when I shut my door!! HELP
My driverside doorlock automatically locks itself when I shut the door, but it only happens once in a while, I have already locked my keys in the car once with my son inside, what could this be??
Old Apr 16, 2005 | 11:05 AM
TrueUntilDeath.com's Avatar
Default Re: door lock automatically locks itself when I shut my door!! HELP (Rpizzle)
sounds like a problem with the alarm's brain
Old Apr 16, 2005 | 04:34 PM
kuja's Avatar
Default Re: door lock automatically locks itself when I shut my door!! HELP (TurboPandaRFL)
dude. i think i have the same problem. Does it lock again if you unlock it w/ the button?
when mine locks, i can't even push the lock manually, it just freezes there.
wierd
Old Apr 16, 2005 | 08:07 PM
Rpizzle's Avatar
Default Re: door lock automatically locks itself when I shut my door!! HELP (kuja)
dude mine does the exact same
Old Apr 16, 2005 | 08:17 PM
kuja's Avatar
lets start a club
Old Apr 16, 2005 | 08:25 PM
Rpizzle's Avatar
Old Apr 16, 2005 | 08:59 PM
ReggaePoweredDC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kuja &raquo;</TD></TR><TR><TD CLASS="quote">lets start a club </TD></TR></TABLE>
Add me to the member list. Last week when I finished working I started my car (with door open so it wont lock). I close the door and was standing outside the car talking to someone and it just locked. Had to wait for someone to bring me another key/alarm to get the car open.
I wanted to pop the hood but I took care of that easy access to stop theieves ... lol worked against me.
Old Apr 16, 2005 | 09:12 PM
Liquidgsr's Avatar
Default Re: door lock automatically locks itself when I shut my door!! HELP (ReggaeBai)
check your fuses. I had that problem
Old Apr 16, 2005 | 11:37 PM
kchungb17a's Avatar
Default Re: door lock automatically locks itself when I shut my door!! HELP (Liquidgsr)
Could be your drivers side door lock actuator malfunctioning. Make sure your alarm is working correctly. Of course if the alarm's malfunctioning, it would also arm itself, not just lock the doors. Another thing to check is the door harness connector that goes into the car at the door jam. Sometimes moisture can get into that plug and cause some weird ****. Good luck guys!
Old Apr 16, 2005 | 11:59 PM
AspectIndustries's Avatar
Default Re: door lock automatically locks itself when I shut my door!! HELP (kchungb17a)
The actuator is bad or something. I got the same problem, but...
My **** stutters every time I unlock.. O wellz, time to replace..... As i was told..its $20 to replace, not to bad i guess.
Old Apr 17, 2005 | 12:40 AM
kchungb17a's Avatar
Default Re: door lock automatically locks itself when I shut my door!! HELP (synik)
Hey synik! You gettin around too huh? $20 sounds really low to me. Even w/my employee discount, I think it was... $45 or so.
Old Apr 17, 2005 | 05:38 AM
BigDaddyRich's Avatar
Maybe your switch is stuck in the down "Lock position" internally? Try unplugging the drivers side door lock switch from the harness and see if it still happens? Then try locking and unlocking your doors with the passenger door switch?
Thats the only thing I can figure out, unless its only your DOOR that is affected? then its gotta be something local to the DOOR.
LT Link
Nov 5, 2019 01:17 AM
2003CivicLx
Sep 18, 2008 05:14 PM
JDMjukie
Mar 12, 2007 08:21 PM
97RSTEG
Jul 11, 2006 08:05 AM
Smith Wise
12
Aug 17, 2003 12:03 PM
