2nd Gen Preludes
Old Jan 30, 2002 | 06:08 AM
onerudelude's Avatar
Default 2nd Gen Preludes
Just wondering who else is running a second generation prelude.. I just bought mine... its an 87 1.8 Dual carb... anyone have any modding ideas.. Please help!!! any pics would also help... Just looking for some ideas... Please Help!
Thanks
James
Old Jan 30, 2002 | 06:26 AM
hensley's Avatar
Default Re: 2nd Gen Preludes (onerudelude)
I autocross an 85 Prelude in EP.
Old Jan 30, 2002 | 07:32 PM
Its to Bad they don't make very many after market parts for our 2nd Gen Cars... I mean they do have a potential at makin a killer car from a carb engine...Sure Fuel Injection is nice and the DOHC and VTEC... but same amount of power can be pulled with a bit of motor tuning and some carb work.... Be nice if honda would make some of these parts available for us,, instead we have to pull parts from here and there to make fit on our cars to achieve the performance gain wanted.. Just my $.02... what kinds of mods have you done to your motors to pull max power???
CHEERS
Old Jan 30, 2002 | 08:46 PM
4wsB21a's Avatar
New User
good luck finding a header, but you may get lucky. get a custom exhaust done, upgrade your carburetors, or port and polish them, bore and resleave your engine to be a 2.0 (not too sure about that one, but it is a good idea to look into), get higher compression pistons, a different fuel pump to get more fuel to the carbs, a custom intake, performance plugs and wires, advance the timing by a few degrees to get a higher top end power instead of all low end, remove the a/c and all it's components, shave the head down to get higher compression, and then maybe you will have 120 whp, if you are lucky. your first efforts should be on the suspension so you can attempt to outhandle other cars cause you have a lot of work to do to out power them.
good luck.
Old Jan 31, 2002 | 07:27 AM
Missingsohc's Avatar
i have one it is nice lol
Old Jan 31, 2002 | 01:01 PM
hensley's Avatar
Default Re: 2nd Gen Preludes (JDMET-2)
A header for an 86 Accord will fit the head. You'll need some modifications where the pipe passes under the front cross member.
Old Jan 31, 2002 | 06:48 PM
4wsB21a's Avatar
New User
Default Re: 2nd Gen Preludes (hensley)
a header for an 86 accord will fit the 1.8 prelude motor? where can you get a header for the 86 accord?
Old Jan 31, 2002 | 07:21 PM
hensley's Avatar
Default Re: 2nd Gen Preludes (crxplus)
Try Pacesetter, they used to make one. Its the only option I know of, other than having one built.
Old Feb 1, 2002 | 01:34 PM
actually the si model header will fit because the head is the exact same!!! try pace setter or dc sports if you wanna pay out the @$$ i found mine in a junk yard for 50 bucks it is a racing only 4-1 whit one of the sweetest merge collecters i have seen. lots of people made a header for this car i know about all of them go check my profile on honda prelude.com 2nd gen dtmshogun........
Old Feb 2, 2002 | 02:07 PM
4wsB21a's Avatar
New User
the si prelude model for that gen is a 2.0 fuel injected with four ports coming out of the head. the dx model is a 1.8 with only three ports coming out of the head. at least, that is what it looks like on mine. i haven't taken the manifold off, but there are only two normal sized ports and a large port in the center. how can that be the same?
Old Feb 2, 2002 | 03:32 PM
I have an 88 Lude with a 2.0L for parts,,... Would the header off it fit my 87 lude 1.8L???? if it will I'll swap them... anyone else done this??? any gains in power with this done??
Old Feb 2, 2002 | 07:04 PM
It is the same.... the engines have the same head design. They call it a Tri-Port or Syamesse Port. So yes the 2.0 Si header will Fit. Hope this helps.
Old Feb 3, 2002 | 05:54 AM
the second gen prelude was from 1983-1987which makes your 1989 prelude a 3rd gen and the heads are not the same from gen to gen....hope this clears things up.
Justin Meiring
Oct 24, 2014 02:16 AM
vlocka
May 10, 2013 01:32 PM
mane793
Feb 3, 2007 12:57 AM
mike3
Sep 30, 2004 11:35 PM
