Some axle related questions
I replaced my passenger axle couple of days ago and I have been wondering about the appearance of the inner boot when I installed it. Instead of it being the normal ribbed shaped, it seems stretched as if all the "air" was sucked out. I'll take pictures when I get my camera to show what I'm talking about.
Also, I now noticed that I'm getting a popping/clunking sound from my driver side when I'm on the gas. Driver side axle going out too?
I know what you're talking about. Sometimes, when you go to install the axle, it'll fall out in the boot. You'll need to remove the axle from the hub and just wiggle the axle around till it looks right. Right now, don't drive your car until it's fixed.
Well damn, I've been driving it since I put everything back together. Everything sems fine except for tha appearance. I figured it would come out it doesn't seem like it did. Man... It was hell trying to take out the spindle.
I feel you on the removal of the axle from the spindle! Mine was a pain too. I think my driver side axles looks like what you are talking about, stretch or something. I have been driving on it forever and never had a prob. I think it could be normal since there is room for the axle to move in and out thus stretching the boot. I think i'll take a look at mine tomorrow and feel the boot to see if anything is fishy.
well here's a pic i took when I pulled the old axle out and compared it with the new one. From what you can make out, it would see that the new inner boot is not high up enough so to where it would look like the old one.
edited with paint to help with visualization of what I'm trying to say
well I jacked up the car and took some pictures with my camera phone.
Here's how the inner joint looks when I pushed the axle out of the hub:
It looks like it should. But the outter CV isn't in the hub:
Here's how he inner joint boot looked before with the everything bolted down and in place:
Man... I think AZ gave me the wrong axles... Is there any difference in length between manual and auto tranmission axles? This is for the passenger side.
my 2 cents: you got the wrong axles. do you have a swap? the axle seems to be too short for your application. you can tell from your pics that the new axle is shorter than the old one.
i have a right hand drive, so im not sure how it will work with left hand drive, but did you get the correct size for the side you need to replace? I know that on my car the drivers side driveshaft is smaller than the passenger side... hth
well i pulled out the axle and brought it back to AZ to compare it with another 7078. Come to find out that the axle I got was packages wrong. I wonder what it came off of. The part number on it was 8428. Well the problem is solved and so is my broken lug stud. I just need to get around to tackling the driver side axle now.
integrainside
Transmission & Drivetrain
Oct 3, 2013 05:21 PM
Pwnmeister
Jun 25, 2013 07:55 AM
