clunk/pop from front suspension (searched)
Old Apr 15, 2005 | 12:44 PM
thehatchninja's Avatar
Default clunk/pop from front suspension (searched)
my search found so many different problems, and I have some ideas, but i want some input.
here's my suspension
KYB AGX
H&R race (integra rated)
here's my problem
whenever there's a weight shift (braking/cornering) there is a clunk/tap/pop from the front left suspension. from what i read i think it might be that i need more shock travel, so i was considering getting the GC upper mounts, but i know there are many people who don't have this problem with similar setups.
any suggestions. I don't want to buy somethign i don't need.
Old Apr 15, 2005 | 12:50 PM
Default Re: clunk/pop from front suspension (thehatchninja)
this is an awesome thread i found
https://honda-tech.com/zero...age=3
unfortunately i don't have a welder and can't afford the down time for this DIY, since this is my daily driver. The GC extended upper mounts seem like they would solve the problem.
TeamNextGenChris's Avatar
with that spring i doubt you're too low to be bottoming out,especially with a good shock.
check your ball joints,tie rod ends and wheel bearings for play.also,check the control arm bushings.
if all that checks out,possibly an axle,although it would probably be making noise other times too.
Chris
Old Apr 15, 2005 | 12:54 PM
Default Re: clunk/pop from front suspension (TeamNextGenChris)
thanx for the reply, shouldn't be the axle, i just replaced it, i'll check the other stuff.
Old Apr 15, 2005 | 07:07 PM
pancake56's Avatar
same problems here. front driver side. I keep thinking its my door. or the left front shock. any suggestions would be greatly appreciated.
Old Apr 15, 2005 | 07:25 PM
Default Re: clunk/pop from front suspension (pancake56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pancake56 &raquo;</TD></TR><TR><TD CLASS="quote">same problems here. front driver side. I keep thinking its my door. or the left front shock. any suggestions would be greatly appreciated.</TD></TR></TABLE>
read above-make sure everything is tight,not worn out or broken.
Chris
Old Apr 15, 2005 | 08:52 PM
tur3oDC4's Avatar
check your upper control arm nut. my freinds just fell out.. it was messy
Old Apr 15, 2005 | 09:25 PM
deviant1's Avatar
Default Re: clunk/pop from front suspension (whitepoweredlsvtec)
check to see if your upper control arm is hitting the shock tower. I you cut the bumpstops when installing h&r race springs, it will DUMP the car. Other than that, check to see if the coils on the springs are rubbing or hitting each other. Sounds odd, i kno but when i had h&r race springs, i had a clunk from my pass side rear. I swapped out the springs for some ground controls and the sound went away.
Old Apr 17, 2005 | 08:45 PM
bump....need to check this...maybe tomorrow.
ednyboo
Dec 7, 2007 04:00 PM
CircuitFG
Mar 4, 2005 06:20 PM
crs
23
Jan 18, 2003 07:53 PM
